anyone wanna help?!?!?! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-17-2012, 05:14 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Originally Posted by latech
there could be a mix up with timing tabs and balancers. There are 3 different setups, for gen 1 SBC making it possible to have 6 incorrect combinations.Only 1 correct combination.
Just a thought.
I got the wrong one before so I just cut another groove into it.
But if you don't know its the wrong one, things won't be quite so simple.
Name:	DSC02982 (Small).JPG
  #17 (permalink)
Old 02-17-2012, 08:34 PM
foodstamp's Avatar
poor boy's racing
when i first got my truck, i was doin some p/m on it an i ended up getting my cap on dizzy bout 45* off and got the same problems as OP is having, crank crank cranck but no start... that was a lesson learned as the cap an sit 2-3 ways on the dizzy and make ya contacts for each cyclinder out of whack... id suggest turning cap one click left or right and resnap the hooks and try again as thats what happened to me once i took my cap loose to make sure my advance was working.
  #18 (permalink)
Old 02-18-2012, 04:53 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Originally Posted by Low82C10
yes i made sure i was on compression side, made sure the mark is on 0 and set my rotor to point towards the 1# on the dist. cap. still nothing just cranks and cranks
If you want to be 100% sure, take off the valve cover and check that both valves on #1 are closed at TDC.
  #19 (permalink)
Old 02-18-2012, 03:52 PM
i took cover off,how can you tell if the valve is closed? if they valves weren't closed, wouldn't they be no air coming from1# spark plug hole?
  #20 (permalink)
Old 02-18-2012, 04:09 PM
when your at tdc on number 1 both your rocker arms will be up..turn your engine by hand a you will get a good idea on full cycle..also put your finger over spark plug hole and wait tell you feel air pushing passed your finger then wait tell your roker arms both come up..check your mark on balancer
  #21 (permalink)
Old 02-18-2012, 04:37 PM
i did that, just now i had helper crank engine, air came out 1# and i hand cranked it the rest of the way.while doing so, i was watching the valves up and down, on the 1# cylinder they never seemed to both be all the way up at the same time?? one would go up then come down but not all the way down and both would stay somewhat in the middle. never did i see them both up which i would assume is closed.
  #22 (permalink)
Old 02-18-2012, 04:50 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
The arm where it contacts the valve tip , both should be at the highest position , not one up ,one down.
Valves are closed when the valve tip is up. The spring pushes it up closed.
  #23 (permalink)
Old 02-18-2012, 04:56 PM
thats what i was saying, i know they had a higher point then where they are sitting on the timing mark. one would go up all the way up but i didnt see both of them go up as high as one along would go up at the same time. and doesnt the spring push the valve open?
  #24 (permalink)
Old 02-18-2012, 04:58 PM
ohhhhhh now that i look at your picture, that makes sense i was thinking the other end was the valve i was looking for both to be up, and now i get your point on the spring pushing it closed. sorry my bad,back outside i go.
  #25 (permalink)
Old 02-19-2012, 03:10 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
So, how you making out?
Here's what I wanna do Wrenchmonkey Introduce Yourself 3 03-11-2008 03:56 PM
Just Wanna Say Hi MYDREAMGTO Introduce Yourself 2 01-27-2007 07:00 AM
Wanna see my....... Beenaway2long Hotrodders' Lounge 5 01-30-2004 03:51 PM
350 wanna go with EFI - what do I need? THC3PO Engine 7 06-06-2003 09:14 PM
