Anything wrong with this engine combo?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2007, 10:03 PM
hey all, I'm building a budget SBC to go into a jeep scrambler, It will have a manual tranny behind it (SM465) and and Rv cam, Most of the work will be handled by the local machine shop, and this engine will probably never be rev'ed higher than 4500, so here is my combo, let me know if anything is wrong\
late 70's 350 block 2 bolt main, stamped conv.
block came out of a 1977 blazer, had a 4brl on it.
Bored, honed etc.
oil holes debured
crank checked
rotating assembly balanced
stainless valves/rebuild 441x heads
rebuilt q-jet
heads/intake port and gasket matched
RV flat tappet hyd. cam 206/214 with 430 lift intake/450 ex.
Edelbrock performer manifold,
exhaust will be handled by whatever manifolds will fit in the jeep frame, and some more quiet performance mufflers,
I am hoping for around 320 horse, with around 400 torque
Also, how much should i shave off the heads/block if i want to decrease the chamber size but still get a streetable compression???
thanks
Old 03-04-2007, 10:38 PM
techinspector1's Avatar
Wiki Edits: 326
What's the static compression ratio?
Old 03-04-2007, 10:44 PM
GM Tech
I would go with a 383 for more torque-torque is what you are looking for unless blasting through mud is all you want to do with the Jeep. You also don't want overly high compression for low speed crawling.
Old 03-05-2007, 05:05 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Sounds like you're pretty close to where you want to be depending on compression and camshaft. What is the exact cam? Need to know advertised duration and Lobe Seperation Angle also. What do you mean by "streetable compression"? Any compression ratio is streetable IF you can get the right fuel. Do you mean you want it to run on 87 Octane? What piston configuration are you running, flat tops with valve reliefs or dished? Your "Dyanmic Compression Ratio" is going to be the deciding factor, to figure that we need to know the above items plus what head gaskets you are using and the deck height of your pistons, in other words how far down in the cylinder is the flat of the piston from the top of the block when they are at TDC?
Old 03-05-2007, 07:17 PM
DeathRattle's Avatar
Some Punk Kid
I dont think you will get that much power with that combo even at the flywheel especially at that RPM.
Old 03-05-2007, 09:14 PM
update
Ok, to answer some questions, I was going to go with a 383 kit, but I already have the flywheel for the 350 and don't feel like buying another. So 383 is out unless someone is going ot give me a deal on a kit.
I know that power output can be manipulated, and that the numbers can be fudged easily, but several different sources list similar power output with very similar combos, only thing different was headers and a holley instead of a q-jet
I have no idea what static compression ratio is, but I was going to stick with flat top pistons, with the four valve reliefs unless I find something better cheap. I would love to run 87 octane swill , but if i have to run 92 that is ok also cause the jeep will be a weekend warrior,
thanks again for all your input!!!
ps the cam is listed in summit racing it is a lunati truck advenger, part number lun-90350lk
Old 03-05-2007, 09:53 PM
Some Punk Kid
http://www.jegs.com/webapp/wcs/store...61559_-1_10185
350 Journal crank with 3.750 stroke Internal balance 2pc seal. Decent price. 383 and you can keep your flywheel.
CA smog questions...engine swaps curtis73 Engine 25 11-28-2012 08:11 PM
Whats wrong with my combo 1985fiero Engine 11 07-12-2006 08:31 AM
my new engine combo predator carb guru Engine 1 01-22-2006 05:38 PM
Figured I'd ask here SBC INFO ENGINE COMBO SITE??? DeathByGreaser Hotrodders' Lounge 3 08-25-2003 11:33 PM
I have oil on the wrong side of the engine............ The Vandal Engine 5 02-25-2002 10:47 PM
