anyway to get primer fillers to spray smooth - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2009, 07:41 PM
I am trying to get slicksand to spray right.I have thinned it 10 percent and adjusted the pattern and flow. Adjusted air pressure to gun pressure.The spray I get is not uniform and not even close to smooth.Does this stuff Just spray rough or is there something else wrong?The spray gun is a cheap hvlp gun with a 2.4 tip. Any help would be appreciated. thanks phil
Old 05-16-2009, 10:29 PM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
A 2.4 tip? Wow. That's huge! It should hose out of that gun like no tomorrow. Thinning should NOT be required in this case, actually I would expect that your fluid needle should be choked off a bit to prevent to thick of a coat. So maybe something is wrong with your gun or gun adjustment.
Though I should add that Slick Sand will not ever lay out like a urethane primer will, it is essentially sprayable polyester putty...
Old 05-17-2009, 06:49 PM
S10xGN's Avatar
Gotta love a turbo!
You're not getting enough air. Let me guess, you have the old 3/16" ID quick-connect fittings? With these I can say for sure, removing the regulator and opening the air up completely will still not give enough "cap" pressure to spray correctly. Just a switch to larger HVLP style fittings will do you a world of good.
Russ
Old 05-18-2009, 11:53 AM
Practice on panels other than your car
Practice with different set ups, reducers, flow rates, air patterns. Rememeber painting is a process control experiment. Change one thing at a time, keep notes. Work with samples until you get the results you want. Then move to the car. Once you get it right shout Eureka!
Spray on fillers camino75080 Body - Exterior 21 11-07-2008 12:57 AM
Brand of weld thru primer modas Body - Exterior 4 01-12-2006 02:05 PM
Lacquer primer question badriand Body - Exterior 18 07-23-2004 03:08 PM
Epoxy primer over paint? 1960 Trucks Body - Exterior 4 03-02-2004 02:25 AM
oh no. cheap primer? dh79 Body - Exterior 6 09-10-2003 06:16 PM
