Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - AOD to 302 kickdown adjustment
Old 05-05-2012, 01:24 AM
JeffB's Avatar
JeffB JeffB is offline
To properly set the AOD cable as per the instructions you first need to bring it up to operating temperature then with the idle at about 700 RPM adjust the cable so there is zero slack with a gauge in the pressure port you should have 0-3 PSI. With the tool that came with the LOKAR cable installed pressure should be 30-35 PSI here is a how-to video: http://www.youtube.com/watch?v=jZwsQViZilQ Look at the picture below,sometimes the Lokar return spring is too weak Lokar is aware of this but have not fixed the problem and here is a fix in the picture.
Name:	HI REV GOV 2.jpg
