AOD to 312 57 T-bird - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2005, 03:14 PM
BarryK's Avatar
I wrote in a while ago about this project and here is an update.
Its just to simple to do! This was done with the Bernstein adapter.MN
The engine and trans is now in the car. I'm impressed with the precision in witch these parts were made and the fit.
This was a pretty simple job biggest pain in a** was using a 3 inch grinder to make sure starter had clearance in the aod. Just tedious is all, grind and fit and grind more.
Second pain was the TV cable, I bought the locar kits and poor instructions but figured it out and than said after seeing it I can make a better holder myself so took apart and made my own bracket.
The driveshaft fit in AOD and is perfect length, so that was a plus.
If you switch the front motor mount around the trannie mount will line up with existing hole but to drop the AOD pan in future you would have to jack up trans a few inches.
So, I have decided tonight I'm going to cut the front part of the piece that the trans mount bolts to and add a mount on the back. This is not necessary but in my book it will be a neater installation and easy to get pan off.
The mount is not structural and is only a piece of plate mounted to frame with a weld.
Old linkage works fine but cannot put in low, it would be easy to modify this but I don't need low as it starts there anyway.
I have not even looked at speedo cable yet, so may have to order one for AOD.
This is an easy installation but requires many checks and rechecks to make sure everything is right. I ordered a built AOD (level 1 up to 350 hp) with lock up torque converter from the transmission center in LA and had to buy locar kit and trans cooler and lines so at this point I have about $1800 invested and maybe 20 hours of work with about one hour of cutting and welding and 3 more hours left of hook-ups.
Last time i posted i said I would take pictures, well its to easy of a job and i saw nothing that needed a picture. On regulars ford may not even need to pull engine but the T-bird an auto trans is not coming through the Xframe for sure.
Barry
Old 03-09-2008, 02:24 PM
Last journal entry: Progressing...
Shifter
Barry,
I take it you used the original shifter? Was it a painful ordeal to get everything synced up?
Matt
Bolt AOD to Ford 312 randyveach Transmission - Rearend 10 03-10-2008 10:08 AM
AOD to 57 T-Bird BarryK Transmission - Rearend 14 03-22-2007 09:44 AM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
Replacing C4 with AOD Mustang50Clay Transmission - Rearend 5 05-04-2004 05:24 PM
AOD Metric mustang66maniac Transmission - Rearend 4 08-05-2002 10:52 PM
