Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - AOD conversion
Thread: AOD conversion
Old 10-05-2002, 07:56 AM
dmorris1200's Avatar
dmorris1200 dmorris1200 is offline
doesn't play well with others
Post
Suposedly these guys have a lot of info, got this link from KULTULZ on earlier post- <a href="http://www.baumannengineering.com" target="_blank">www.baumannengineering.com</a>
They have a lot of different options for you depending on whether or not you're looking for a budget swap or not. Main thing I always here if going with an AOD is make sure you set your tv cable correctly to control line pressure in the trans, there is no kickdown lever. If you have $$$ it looks like they've done some neet stuff with the AODE and control box for swapping into older cars. I'm sure you'll be getting more info once others have read this.
BUILT FORD TOUGH
