Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - AOD conversion
Thread: AOD conversion
Old 10-05-2002, 03:45 PM
woodz428's Avatar
woodz428 woodz428 is offline
Troll Hunter
Post
If you have the money the AODE is the way to go although it is a little bigger ( I think), that shouldn't be a problem in a '70 'stang. Of the straight AOD's, the GT mustang or one from a Lincoln LSC is the beefiest. The post was correct about the T.V. adjustment, it is entirely different than the old kickdown rod Ford used for years and won't work off of a kickdown linkage. Also Lentech makes some great valve bodies that re-route the hydrailic system to make the AOD just about indestructable, check them out.
