We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 03-26-2002, 01:01 PM
melbishop melbishop is offline
New Member
Post AOD ford transmission
Will a 80's AOD ford (overdrive tansmission) bolt to a 260 Cu.In falcon engine? If not I'm looking for information.
Old 03-26-2002, 02:38 PM
dmorris1200's Avatar
dmorris1200 dmorris1200 is offline
doesn't play well with others
Post
It should bolt up to the 260. Just make sure it's an AOD and not an AODE trans. Is the 260 still in a Falcon? Haven't seen one of those in a while.
Old 03-26-2002, 05:49 PM
New Member
Post
Yes the engine is in a 63 falcon futura two door hardtop. Thanks for your input.
Mel
Old 03-27-2002, 10:21 PM
mustang66maniac's Avatar
mustang66maniac mustang66maniac is offline
Ford Freak
Post
it should bolt right up. if it came from a 5.0 and has the right belhousing. the 260 is the same family as a 302. Im pretty sure they didnt change the bolt pattern. I could be wrong though.
Old 03-30-2002, 02:16 AM
Customcab Customcab is offline
Post
The 221, 260, and early 289's had a 5 bolt bellhousing. The later model ( 65-on small blocks) had 6, and won't interchange. Phil
Old 03-31-2002, 12:54 AM
gordon kitson gordon kitson is offline
New Member
Post
if your 260 is the same as a 300 it should houk up on fords the 300,302,and 351c all us the same tranny good luck with the falcon if i were you id go v8 butt thats just me do the 6 right by puting a 4bbl on her because the first and sixth cyl starve for fuel look out 6
Old 03-31-2002, 09:26 PM
Ford Freak
Post
What?! Hey guess what gordon, the 260 is a v8. Ford made 5 windsor v8s that were the 221, 260, 289, 302, and 351. This guy's abviously talking about the second one. Ford used them before the 289, 302, and 351 were even created.
Old 04-02-2002, 04:51 PM
Tom Tom is offline
Post
the 63 block will have a 5 bolt pattern and won't fit the AOD mid 65 289s started the 6 bolt pattern
Old 04-10-2002, 03:53 PM
New Member
Post
[quote]Originally posted by Tom:
<strong>the 63 block will have a 5 bolt pattern and won't fit the AOD mid 65 289s started the 6 bolt pattern</strong><hr></blockquote>
When you mention 5 and 6 bolt patterns are you talking about the transmission bolting to the bellhousing or the bellhousing bolting to the engine.
[ April 10, 2002: Message edited by: melbishop ]</p>
Old 04-11-2002, 12:29 AM
trophy trophy is offline
New Member
Post
Tom is right. You can get a 5 bolt belhousing to fit the C4. Kind of rare, I got one from mustang ranch in WA. and sent it back. Would you like to by an original 64 1/2 289, cheap? The best you can do is the C4 or fordomatic. I changed engine and all. good luck.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
