AOD Front Pump Bushing - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2005, 12:12 PM
Nitrospud's Avatar
New Member
Just a quick one for you guys...
I'm nearing the end of my AOD build up and want to press in the new pump bushing. I marked the location of the notch in the bushing before pressing the old one out. Trouble is, the (poor) picture in the manual, shows it in a slightly different orientation. How critical is the location ?
Old 10-09-2005, 10:26 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
groove opening faces the interior of the pump...
notch/groove positions in the center of the solid spot between the open sides of the pump body.
hope that is clear, late , but clear.......
Old 10-10-2005, 06:13 AM
Nitrospud's Avatar
New Member
Thanks for that !
Funnily enough, thats what the book states, but it's not how the original one was installed.
Front Pump Question? Marcus Transmission - Rearend 2 11-15-2004 09:53 PM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
Front pump seal 700r4 KeithB123 Transmission - Rearend 4 09-29-2003 07:19 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
WOT stalling Camaro76 Engine 5 04-13-2003 11:26 AM
