aod kickdown cable - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2003, 12:29 PM
Post aod kickdown cable
I've heard of people running a three-speed automatic trans without a kickdown rod and I've even done it for a little while. It seems to work okay for the short time that I did it. The question is----- Is it esential to use a kickdown cable for an aod ford trans and, if so, could someone please help me to understand why. What's happening in the trans to make this nescesary?
Old 04-18-2003, 01:53 PM
airworld2's Avatar
Post
aod trans will need t/v cable connected will either shift early and burn up transmission if 88 or later, early model would shift late depends more on valve body used here, but you need rod or cable connected for all to be good.. why it needed the tv ( passing cable, not correct wording for this transmission) shift timing and line pressure. fast answer
[ April 18, 2003: Message edited by: airworld2 ]</p>
airworld2
