AOD quick shift problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2008, 08:07 AM
Cobralcon
Last journal entry: Daytona Turkey Run
I'm having a problem with my '87 based aod, no e that has just been rebuilt with shift kit, valve body mods, performance clutches and using a Lokar TV cable that has been set via pressure gauge by Tranny Shop.
The problem is a quick or "skip" shift from first to third with little or no time in second. The mechanic at the Tranny Shop believes it has to do with a sprag spring (too weak or too strong) on the output shaft and the high gearing of the rearend (2.88 to 1).
Before I give the go ahead to start exchanging springs i'd like the input of the expertise that exists on this forum.
Thanks in advance,
Hal R.
Old 09-17-2008, 06:38 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
A mileage number would be great. (maybe a worn out TV plug sleeve - pic)
Also, what was the AOD out of originally?
Gearing of that truck/car ?
I think the governor springs are the ones that may need changing. Not the 'sprag' springs you stated.
Try and tighten the TV cable a few turns and try that.
Old 09-18-2008, 10:58 AM
Cobralcon
Update on AOD
C-10 First, thank you for the reply. I haven't seen a lot on my particular problem, mostly on size installation issues of the tranny into another application.
Basically no miles on the AOD, it was completely rebuilt, valve body high performance kit, new and more high performance clutches, brand new TV Lokar cable all done by a mechanic that's rebuilt many trannys, ford, gm and chrysler as well as some foreign.
The AOD was pulled, along with the 5.0 engine, out of an '87 Mercury Marquis and both were totally rebuilt. The engine is now a 331 cu. in. switched to carburetor (Holley) and runs strong.
Now the rear gear, and this may be the problem, is a 2.88 to 1 eight inch Ford. Because it is geared so high (low numerically) the mechanic who rebuilt it feels like the springs on the output shaft (whatever they're called) need to be either stronger or weaker to compensate for the rear gear ratio which is substantially higher than what this tranny was originally used with.
Any other thoughts this additional information may have triggered are appreciated, especially if you have any idea in which direction we need to go with the springs, stronger or weaker.
Thanks again and have a good day,
Hal R.
Old 09-18-2008, 07:55 PM
Crosley's Avatar
Wiki Edits: 1659
An AOD trans does not have weights and springs on the governor as some folks have seen on a GM transmission.
The AOD governor is prone to sticking after a rebuild. I would pull the tail housing off. Remove and clean this governor.
Usually on an AOD trans the problem will be no upshift or late upshifts ... this is caused by wear in various areas of the governor oil path. When the gov circuit loses pressure th e shifts will be late.
Old 09-18-2008, 08:12 PM
C-10's Avatar
Revolution Calling
Well, an AOD-Hi-Rev kit from TransGo has some proprietary springs in it... What are these for?
Weights no, springs yes?
Old 09-18-2008, 08:30 PM
Crosley's Avatar
Wiki Edits: 1659
My point was the AOD governor is not a similar design of the GM style governor that many people are familiar with . you can not simply pop in 2 different springs or grind the weights
The hi-rev kit of TransGo has a weight and spring in the kit. I usually toss this hi-rev kit away.
Old 09-21-2008, 05:56 PM
Cobralcon
C-10, Crosley,
Thanks for your inputs.
I'll start by insuring the TV cable is taught and if that fails to fix the issue I'll pull the tail housing and clean the govenor.
Thanks again.
Hal R.
Old 09-21-2008, 06:03 PM
Crosley's Avatar
Wiki Edits: 1659
I did not address this question...
there are springs for a shift valve in the v-body. Also a special weight and small spring for the governor.
This AOD governor is a wacky looking compact design , not like a GM design or a Mopar design.
Old 09-21-2008, 06:09 PM
Crosley's Avatar
Wiki Edits: 1659
Originally Posted by bbfalcon
C-10, Crosley,
Thanks again.
Hal R.
the small weights in the governor only install correctly in one direction , how ever they can be installed incorrectly and bolted together.
Your quick shifts point at this gov IF the TV linkage - cable is operating close to Ford design. The AOD usually suffers from delayed upshift or no up shift from leakage in the governor circuit.
Add to that , the recent rebuild with shift mods that "may" have been performed incorrectly...... I recently had a seasoned builder goof on some shift mods on a GM transmission.... so "stuff" does happen
Old 03-01-2012, 07:57 PM
AOD early light thottle upshift fix
The AOD transmission is sensitive the ratio of the thottle lever on the carburator. The ratio has to match the thottle valve lever on the transmission if this is off the trans will never shift right. The Holley carb lever is wrong and so is elderbrocks and Demons! Sonnax transmmision industries makes bolt on tv cable geometry corrector available thru TCI Summit and transmmision shops works for 700r4 2004r as well. Transgo hirev kit works well with their shift kit for later mid to full throttle upshifts up to 6000 rpm s use with lokar cable kit and watch the angle of cable to lever the strater the better .I recomend 3.50 gears or lower for od automatics. Garry Quality transmmissions in Seaside.
blower idle rpm problem Ratoflic Engine 7 12-01-2008 03:31 AM
700r4 shift lever problem kbyounger Transmission - Rearend 1 05-02-2008 06:04 PM
700R4 2-4 shift problem 90GMCVortec Transmission - Rearend 9 04-12-2008 09:17 PM
turn signal problem, need quick fix 71gtx Electrical 6 06-09-2004 05:52 PM
TH 400 shift problem BigBlock69 Transmission - Rearend 34 02-03-2004 11:43 PM
