AOD Rebuild - Worth the Trouble??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2006, 01:14 PM
I was about to start a rebuild on an AOD, but when I got to looking at the unit, I realized it's an early (1981) tranny. I know there are issues with those early ones, but can they be overcome with a good rebuild kit and the appropriate shift improver kit? It's going into my '65 Mustang which is your basic "Road Trip" car. Rarely rodded, but on occasion it's fun to put that 351W to work. I don't want to put time and effort into this if I can't make it right. It's a freebie, so making it work puts me $$$ ahead.
Old 11-24-2006, 10:35 AM
Anybody out there?
Old 11-24-2006, 10:44 AM
Early AOD suffers from several issues. All can be overcome.
Most of the issues are hard part related and can only be determined by teardown and part inspection. The list is not easliy summarized.
Tear it apart, get a good overhaul and valvebody kit, learn the TV related issues and installation requirements and go for it.
This is NOT the trans I would have a beginner try out. Endplay, proper assembly and clutch clearances, band adjustment, bushings,.....
Perhaps you should consider the local trans shop; a quality rebuild and converter is ~ $900.
Old 11-24-2006, 01:04 PM
airworld2's Avatar
aod
early or late all have 3rd gear trouble, you can change direct drum to later style(more clutch plates) install late valve body and late 3rd accumulator. shift kit would be a good upgrade. and if you have access to a 4r70 w transmission (94 up mustang ,crown vic or pickup ) you can use gear train for a low ratio 1st and 2nd. you might look for another core all the way to 93 just before the went all electronic .aod was a very good transmission suffered from gear ratio issues in direct, caused from direct shaft to converter drive plate. but thats for another day's discussion
airworld2
Old 12-02-2006, 01:24 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
You'll love the OD. They installed them behind 351w in the Vics in the late 80s..... in the salvage yard look for a "square body" Vic with a variable venturi carburetor... that's a Windsor. (5.0s had fuelie)
Generally they will take a lot more abuse than most people realize. Use Mobil 1 ATF.
Don't forget the Windsor has a 28 oz balance (5.0 has 50 oz) and you need a flexplate for that.
AOD to 312 57 T-bird BarryK Transmission - Rearend 1 03-09-2008 02:24 PM
350 Engine rebuild CamMan Engine 35 06-01-2006 02:32 PM
C-4 65 Mustang Tranny Rebuild 65Mustang289HIPO Transmission - Rearend 13 05-02-2006 12:47 PM
88 AOD tranny problems rflud Transmission - Rearend 9 02-17-2003 04:53 PM
My AOD, the full story mustang66maniac Transmission - Rearend 26 01-30-2003 04:38 AM
