Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - aod selector lever
Old 02-04-2011, 10:19 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by half_fast
I'll check the wires in the morning. so if they are different, what does that make this replacement transmission? AFAIK the AOD has a TV cable, and this dont have one. what do I have here?
Did you read my previous posts?
You have an AODE ...... unless there is a W cast into the tail housing on the side. Then it is a 4R70W trans with the W cast in the tail housing.
These two trrans are not swappable because of the gear ratio differences. The vehicle computer will see the different gear ratio in lower gears and set trouble codes
