-   -   aod selector lever (http://www.hotrodders.com/forum/aod-selector-lever-191945.html)
half_fast 02-03-2011 09:50 AM
aod selector lever
hello all, I find myself doing a transmission swap in the 93 town car. a replacement transmission was brought in and I noticed a difference. I'm not sure if its a big difference of not? the slector levers are different! the one in the car has a lever thats ontop, the replacement drops down.
pics:
http://tinypic.com/r/vcqrr5/7
http://tinypic.com/r/2s0nxht/7
from what I've gathered off the internet I think I can just change these out? I also read something about the tv cable, these dont have one?
cobalt327 02-03-2011 12:12 PM
The difference may be caused by one tranny being floor shifted (downward pointing lever), the other column shifted.
I believe that removing the pan and loosening the large nut that holds the lever, you can rotate it to where it's wanted. However, if there's a difference in the length of the arm, this will create a different ratio. If this is the case, swapping out the arm would be the right move- if keeping the original shifter set-up.
B&M makes a kit to allow the use of a 3-speed B&M shifter w/the Ford AOD. It's P/N 40496
half_fast 02-03-2011 11:42 PM
I've taken both of them apart and came across a new problem:
http://i52.tinypic.com/hw03f5.jpg
not sure what to do with this now
Crosley 02-04-2011 05:21 AM
You have an AODE trans , should be a electrical connector on passenger side of an slightly odd shape.
Check the lever for fitment in the replacement trans. Should fit if the model year is near correct.
Check tail housing for a large W cast on the side of each trans. You can not replace a AODE with a trans that has a W (4R70W trans) on it or the other way. The vehicle computer will see a ratio difference. 4R70W has different ratios.
half_fast 02-04-2011 08:49 PM
I cannot find a difference, except for the selector lever. all the plugs are the same, same length, they have the same filters/pans.
old:
http://i53.tinypic.com/15wbcj8.jpg
http://i54.tinypic.com/rmtezb.jpg
http://i54.tinypic.com/33jtiip.jpg
replacement:
http://i55.tinypic.com/egoaia.jpg
http://i52.tinypic.com/wt6790.jpg
http://i55.tinypic.com/2m6ooip.jpg
the only difference thats obvious is the tag. what is going on here? if I cut off the tang from the old one and weld it into the new arm, would the rest of it work fine? I cant simply loosen the inside nut and rotate the other way, the clock position is different. what gives?
Crosley 02-04-2011 09:01 PM
as I posted there can be gear ratio differences if there is a W on the tail housing of one and not the other.
The internal wire harness can be different. Are both harnesses regular wire? Not wires in a hard formed plastic enclosure.
The plug in connector is the smae shape, the pin locations the same on these different trans designs. the wire setup quite different if the wire harness inside is in a hard formed plastic enclosure, not loose wires in a conduit type enclosure
half_fast 02-04-2011 10:04 PM
I'll check the wires in the morning. so if they are different, what does that make this replacement transmission? AFAIK the AOD has a TV cable, and this dont have one. what do I have here?
cobalt327 02-04-2011 10:19 PM
Prolly an AODE.
Crosley 02-04-2011 10:19 PM
Did you read my previous posts?
You have an AODE ...... unless there is a W cast into the tail housing on the side. Then it is a 4R70W trans with the W cast in the tail housing.
These two trrans are not swappable because of the gear ratio differences. The vehicle computer will see the different gear ratio in lower gears and set trouble codes
:thumbup:
JeffB 02-05-2011 05:14 PM
The transmission you have now from the tag in the picture you posted shows it as a 4R trans which has better internals than the the one you want to replace it with.There is a ton of info available on www.clickclickracing.com You would be better served to rebuild the one you already have.
half_fast 02-08-2011 04:22 PM
theres no W on either of them, both have the plain wires, still the only thing that tells these two apart is the lever... what gives?
cobalt327 02-08-2011 04:53 PM
...the only thing that tells these two apart is the lever... what gives?
The lever... AND no TV cable.
half_fast 02-08-2011 05:42 PM
I'm aware of that. these are both AODE, but not compatible
cobalt327 02-08-2011 07:47 PM
The original didn't have a TV cable either?
half_fast 02-08-2011 10:18 PM
nope. they are both darn near identical. neither of them have a W on the tailshaft, all the plugs are the same, filters the same, wires the same inside and out. they are obviously not made on the same day. by at this point I'm totally bewildered and I dont know what I'm gonna tell this guy... take it to the junkyard? I'm temped to jury-rig it with some aluminum and some boat parts in some sort of way. I wonder how they do it at ford garage?
