Aod shifter install - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2010, 06:07 PM
Aod shifter install
I recently bought a 88 notchback mustang, it was originally a 4 cylinder car. Someone decided to do a v8 swap, but they left the 4 cylinder shifter in the car. Therefore the car does not shift like it's suppossed to, I bought an aod shifter used off of eBay and am having some problems installing it. The shifter I bought has a bracket that I am assuming is for the shifter cable but the 4 cylinder shifter does not have this. Are the linkages the same on the 4 and 8 cylinders? And if so where does the cable go? Thanks for any input.
Old 10-30-2010, 11:51 PM
35terraplane's Avatar
AOD shifter
Does it have an AOD tranny in it, was the tranny moved back when the v-8 was put in it? Sounds to me you are going to have to make a new shifter bracket if the tranny was moved a new hole maybe. There is a lot you have not told us.
35terraplane
ST-10 Hurst Shifter jamming Brimstone Transmission - Rearend 1 08-11-2008 03:47 PM
Transmission mounted cable shifter install Countilaw Transmission - Rearend 3 02-08-2008 02:19 PM
87 Camaro shifter cable problems davez28 Transmission - Rearend 2 06-18-2007 05:42 AM
Hurst Shifter Install 383vette General Rodding Tech 0 04-01-2004 06:18 AM
Automatic shifter in pickup floor? newchevyman Transmission - Rearend 5 09-02-2003 06:48 PM
