aod speedo sending unit ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2005, 12:20 PM
56f100's Avatar
does anyone know how many pulses per revolution the stock sending unit is on an 89 aod out of a 89 Lincoln, 8 or 16? I'm putting in a Stewart warner wings 120mph electronic speedometer and have been told by S.W. tech that I need a 16 pulse per revolution sending unit. I still have the original sending unit that was in the AOD, and if its 16 then I can probably use it as compared to paying $100 for the Stewart Warner 82527 sending unit.
Thanks, Devin
Old 09-30-2005, 12:32 AM
New Member
call the service or parts dept of local lincoln-mercury dealer,try parts first and have vin # ready they may need it for any mid-year change that could of happened to lincoln good luck local speedometer repair could maybe help??
Old 09-30-2005, 06:23 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the pulse count is determined by the number of teeth on the metal disc reluctor on the out put shaft.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
feul sending unit failure?? "SLOWMOE" Engine 9 07-20-2004 01:27 AM
tbi 350 oil pressure sending unit problem HELP orangebaja Engine 3 11-07-2003 07:23 PM
Where can I install my water temp sending unit? CHEV66JB Engine 1 05-11-2003 06:15 PM
