AOD Tranny won't go - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2005, 07:15 AM
Cruisin for a bruisin
AOD Tranny won't go
I just swapped in a Grand MArquis '89 AOD tranny into my 68 mustang with a 351W from a Crown vic '87. The TQ was about half full when I put it in and I then proceded to put 5 or 6 quarts of Auto Tranny fluid. I started it and let it run for about 20 min. I then proceded to put it in gear and the car went nowhere! After about 5 more minutes, it slowly went forward when shifted (even when in reverse) Are there any suggestions on what the problem is. I have tried other sites but no one ever answers. Guess I'll ask the pros! THX!!
Old 05-27-2005, 07:56 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
so the tranny is full on the dipstick?
Is this a known good / working tranny?
Was the converter with the tranny when you aquired it?
is the linkage properly hooked up for the shifter?
Is the TV linkage hooked up properly to the carb?
Old 05-27-2005, 09:49 AM
The dipstick has some fluid on it but do I need to check it while its running or not?
The tranny came from a junk yard so I did not see it go. But, the guy told me (I know, they are just words) that it was fine and he didn't want to sell me any AOD on his lot cuz he said it wouldn't fit my 68 coup (he was wrong).
The TQ was original with the car
The linkage is from LOKAR and it is correctly installed with the proper geometry of my stock shifter to tranny
The TV is installed and is tight to the point that any movement by the throttle, engages the TV cable. DOn't know any more about it cuz the car hasn't moved.
Thanks
Old 05-27-2005, 06:19 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
check the fluid with the engine running in park. check both sides of the dipstick.
A junkyard unit that was "fine". Yes that is some what funny.
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
AOD TV port on tranny. which one? murrsue Transmission - Rearend 1 10-02-2004 08:25 PM
88 AOD tranny problems rflud Transmission - Rearend 9 02-17-2003 04:53 PM
AOD Ford tranny (lost fourth gear) shagginwagonvic Transmission - Rearend 8 10-13-2002 01:48 PM
Transplant 302 and AOD tranny into 80 mustang bildo95 Transmission - Rearend 1 08-26-2002 09:47 PM
