Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - AOD Trans
Thread: AOD Trans
Old 10-20-2002, 12:11 AM
mustang66maniac's Avatar
mustang66maniac mustang66maniac is offline
Ford Freak
Post
an aod will fit on a 351. I've never heard of a modulated AOD, but even if you get one that has a tv cable, it can still be done as long as you adjust it right. Separator plate, converter, and flexplate all have to be AOD specific, c4 ones won't work. Make sure you get a 28 ounce balanced flexplate so it will work with a 351 instead of a 50oz unit they put on mustangs after 1982, it also has to have 164 teeth instead of 157 tooth units that came on c4s
