AOD trans fluid - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2002, 03:48 PM
mustang66maniac's Avatar
Ford Freak
Post AOD trans fluid
Windsor-Fox Recommends Mercon fluid for AODs. Art Carr Performance Transmissions recomnends Type-F for AODs because of its superior lubrication. I have art carrs products in my tranny. Which one should I use?
Also, anybody used B&Ms trick shift additive?
Old 12-10-2002, 04:55 PM
BOBCRMAN@aol.com's Avatar
Post
the trans will shift quicker with the f fluid than the dexron-mercon types, different friction values.
[ December 10, 2002: Message edited by: BOBCRMAN@aol.com ]</p>
Old 12-10-2002, 06:22 PM
Ford Freak
Post
quicker as in less RPMs or quicker as in more positive????
Old 12-11-2002, 03:02 AM
aka Duke of URL
Arrow
Safe bet would be to use the fluid recommended by the trans remanufacturer. They may use different clutch and/or band material. Protect your warranty and then experiment.
Old 12-11-2002, 06:30 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
More positive shifts. Type F is compatible in all automatics (Dexron is not). B&M Trick Shift has the same shifting characteristics as Type F, thus can be used in any trans but it costs $$$$ more than the Type F. Go with Type F. 4-jaw will contend that all you need is mineral oil with a touch of red dye #4 and you have duplicated all the tranny fluids!
