AOD transmission swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2002, 10:47 AM
New Member
Post AOD transmission swap
I have a 1970 Mustang with a 351 Windsor and I want to switch my C-4 tranny for an AOD, the question is what year is the best and easiest transmission to use. Any help will be appreciated.
Old 10-07-2002, 04:23 AM
New Member
Post
Doug,
Try <a href="http://www.baumannengineering.com/aodcat.htm" target="_blank">http://www.baumannengineering.com/aodcat.htm</a> they gave me a ton of info when I needed a shift kit for an AOD in my '51 and the kit was easy to install. I remember that the mid to late 80's were better get one that is just befor they started using computers.
Good Luck
DK
