-   -   AOD Trouble (http://www.hotrodders.com/forum/aod-trouble-215630.html)
AnthonySevey 02-28-2012 05:28 PM
AOD Trouble
I have a84 Tbrid 5.0. The transmission is stuck in Drive and under a load in all positions. I have no reverse only drive. I checked the TV cable and it is attached. The transmission was always very strong. Worked great one day next didn't.
Any suggestions?
rick 427 02-28-2012 07:39 PM
Broke shift cable??,,,,or maybe it popped out of the bracket???
AnthonySevey 03-01-2012 09:13 AM
Ford Aod
The cable is hooked to the TBI. It may be broke intenally. I have yet to check that. If it came unattached at the Transmission I would think it would be hanging down. I will haev to getthe car in the air to see if the cable is moving when throttle is advanced.
Thank you,
If anyone has has this issue with their AOD before please advise.
Tony
rick 427 03-01-2012 10:28 AM
no...i'm talking about the trans shifter cable....it's a console shifter,correct??.....does the car hold in park??
AnthonySevey 03-01-2012 01:16 PM
Ford AOD
Rick, the Shifter is on the Steering Column. It will go into Park, but when in Park and the motor is running the transmision is engaged and under a load. It does this in all positions, even Nuetral. The car will only go forward
rick 427 03-01-2012 01:41 PM
Ok then...that's telling me that it is holding in park[altho is under a load,wanting to still go forward]....so your linkage is working....double check everything externally,but it sounds like the forward clutches are stuck on, and that trans is gonna have to come out.....keep us posted
AnthonySevey 03-01-2012 02:02 PM
Ford AOD
Rick, Thank you for taking the time to look into my issue.
I was thinking that the Clutch plates got hot and melted together. I have one last question if you know. Is a C4 transmission better than the AOD that is currently in the car. I will not be utilizing it as a daily driver once I get it all back together. I want the strongest transmission that will bolt right back up.
Thanks again,
Tony
rick 427 03-01-2012 02:36 PM
stick with the AOD,Tony....no need to change it to anything else.
