AOD Upgrade - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2006, 04:12 PM
AOD Upgrade
I want to replace the c-4 in my Mustang with an AOD. The car is basically a driver with a few power adders (351W, a bit of a cam, headers,etc.) running about 280 hp or so. I'll never race the car, but I'll get racy on occasion, so I want the AOD to hold up. What low-buck mods can I do to your routine rebuild to increase the reliability of the AOD?
Old 08-20-2006, 07:34 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Depends which AOD you start with. Try to find one from behind an HO engine, Mustang GT or Mark 7 LSC, they have more disks. You'll need a AOD flexplate with 28 balance for the W, and the usual clutch and oil pressure upgrades. I am also thinking that you will need the starter that comes with an AOD.
A good stock one from an HO will last OK for you. Remember the GT guys souped up their engines and raced a lot until they needed an overhaul.
www.readershotrods.com
AOD to 312 57 T-bird BarryK Transmission - Rearend 1 03-09-2008 02:24 PM
AOD Upgrade Help Nitrospud Transmission - Rearend 4 05-19-2005 08:02 PM
Replacing C4 with AOD Mustang50Clay Transmission - Rearend 5 05-04-2004 05:24 PM
My AOD, the full story mustang66maniac Transmission - Rearend 26 01-30-2003 04:38 AM
AOD Metric mustang66maniac Transmission - Rearend 4 08-05-2002 10:52 PM
