aplying seam sealer - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2009, 08:26 PM
aplying seam sealer
Any prep? Will it stick to weld through self etch primer with zinc?What is the best way to aply it onto a welded rough bead? A brush didnt seam to get into the nuk and crannies without geting it everywhere else?I thought maybe I,d try a small putty knife
Old 04-06-2009, 09:20 PM
what are you applying the sealer on i have to ask? yes its fine over self etch i would remove the weld threw if you can
Old 04-06-2009, 10:01 PM
Here is an article on the subject.. http://autobodystore.com/forum/showthread.php?t=7467
REMOVE the weld thru, it doesn't have very good adhesion properties at all.
Really you should prime it with epoxy or urethane and then after sanding and before painting do the seam sealer.
Old 04-06-2009, 10:04 PM
yes remove the weld threw, i would only apply over self etch, becuase the bond will only be as strong as the stuff your applying it to
Old 04-07-2009, 05:05 PM
The easiest way to get the seam sealer into tight spots is to get a box of throw away gloves and go at it by hand. A finger fits into those spots better than a brush will.
Old 04-07-2009, 09:02 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
After removing the weld thru junk,I would then "try" to smooth the weld bead out then apply epoxy which will go into areas the sealer won't and then apply the sealer over the epoxy after 24 hr. and finish it how you want.
I got a 3 year ongoing project primarily due to cheap seam sealer over etch primer and have seen the end results and damage from this OEM junk.
"If" the sealer had not failed and allowed water to leach under and attack thru the etch,I would have been done 2 years ago with a simple repaint.
Old 04-08-2009, 08:32 AM
boatbob2
seam sealer......
HI,a wet finger will smooth out the seam sealer. i always place masking tape on both sides of what im using the seam sealer on,then seal between tape,remove tape after smoothing.
Seam sealer. BIG DOG Body - Exterior 14 09-12-2007 09:34 PM
Seam Sealer or ? jcclark Body - Exterior 4 05-06-2006 06:05 AM
Seam sealer staying tacky :( Ripped Body - Exterior 4 10-16-2005 01:36 AM
Norton Seam Sealer 67LS1T56 Body - Exterior 4 07-23-2005 10:12 AM
Body seam sealer cruzinTLT Body - Exterior 7 04-19-2005 10:24 AM
