application issues (orange peel)
We are using PPG Delfleet Evolution polyurethane FDXH top coat and F3993 epoxy primer. I have tried every trick I can think of and can't get it to lay smooth. there is always slight orange peel. Has anyone out there used this product. I could use some sugestions. I have used OMNI epoxy primer/waited 24 hours to top coat and had a little better luck.
Moved your post to proper forum and re-titled it for a hopefully better response..Try reducing your material about 5% and work on the gun adjustments..orange peel is usually a gun issue..do some practice runs to get the material to lay down wet and slick..
Sam
Here is a "Basics of Basics" on the issue of atomization which is what we are talking about here. Painting Basics - Autobodystore
Brian |
| The Following User Says Thank You to MARTINSR For This Useful Post: | ||
BWSpaulding (12-10-2012) | ||
| The Following 2 Users Say Thank You to DanielC For This Useful Post: | ||
BWSpaulding (12-10-2012), MARTINSR (12-06-2012) | ||
Delfleet Evolution is a thick product, tough as nails and very suspectable to orange peel, as mentioned by "One More Time", proper gun adjustments can make a big difference, try 5% more reduction, both on your F3993 Primer and your paint...If I am correct, PPG Delfleet Tech sheets suggest using a viscosity cup for this reason and they also recommended for this product to be sprayed with a pressure pot. Using a pressure pot does make a difference with respect to flow.
If you look at factory finishes that have used Delfleet from the factory, they do have a certain amount of Orange Peel as does it's sister of a different mother, Dupont's Imrom. Ray |
Basics Of Basics - Autobodystore Many, and sometimes others are on Camaros.net. Member HOW-TO Paint & Body Contributions - Team Camaro Tech They are also at Autobody101. Basics of Basics | How to Paint Your Own Car, Auto Body Discussion Forum and Videos Making a sticky is all that could happen here but never did when I posted them. Jon asked and honored my request to not put them in the Wiki because they would be altered. Thanks for the kind words. ![]() Brian |
| Orange peel | David buell | Body - Exterior | 13 | 08-17-2009 04:29 PM |
| I always get orange peel! I hate orange peel! | shad9876 | Body - Exterior | 15 | 10-14-2008 08:45 AM |
| Urethane peel or just good ole orange peel? | BIGSKY | Body - Exterior | 18 | 01-24-2007 02:01 PM |
| orange peel | Rustyoldtruck | Body - Exterior | 8 | 07-15-2005 08:24 PM |
| orange peel | CARGUY | Body - Exterior | 7 | 07-23-2002 05:04 PM |
