tried without the filter, and it worked a heck of alot better, still has a textured look to it....it might be the paint itself, or my cheapy gun, or the idiot using it. When the primer was wet i could see a spot where i messed up with the filler too......
Some people just arn't cut out for this i guess
gives me a heck of alot of respect for good bodymen, and crazy metal shapers like randy. The door i primed was hit in an accident and just body filler overtop, so i took out the filler, tried my hand at a dent puller, it came out pretty decent, i thought it was allmost flat, then put chopped fiberglass overtop after welding and grinding the holes from the puller. Then bondo, and i realized that i should have pulled the dent more.
edit: another coat of primer revealed that the first was not super thick, and the apparent indent in the finished panel was the filler showing though the primer. it's all good now
