I would sandblast it and then epoxy prime it..........chances are when you blast it, there will be pinholes right through........
Ontario Rodders |
I would suggest bath it in *Rustmort for a few hours , then rub some 180 grit on it , then bath it in Rustmort another bit and then rinse with water and dry with a heat gun ,180 again then smear a little filler, sand prime etc...
* Rustmort is a brand by SEM and has never failed,,,ever Rx The trick with the rust treatments is to keep them wet with it for way longer then most have patience for. Let it set on there and kinda soak in while you attend other parts of the project etc.. That damage is in a easily repairable spot if 5 or 10 years from now it starts to show ,, |
That is classic seam rust. Let's see what it looks like behind the panel. It's creeping there too, right?
I had to fab up that very piece on my Lincoln. It was beyond repair. I attack surface rust with acid, and I scrub it good with a wire brush until it stops rinsing brown. If there is a way to split the seam and deal with the mess inside there, all the better. If not, clean up real good what you can, on both sides of the metal, epoxy both sides, and renew the seam sealer. As a matter of fact, you should renew all the seam sealer on the vehicle while it's apart. |
I don't have a sandblaster at my disposal but I do have a bunch of different grinders and wire wheels. Not sure how deep the rust goes through. If there are pinholes going all the way through then I will be cutting out that area. I intend on making a street/road coarse car out of it and the last thing I want to cut corners on is the chassis. This is a unibody car and that area is a major source of strength to the car. Might end up putting a small cage in it if I twist the frame too much but that is getting way ahead of myself. right now I jsut want to do this so I am doing it only once.
I do have epoxy from SPI ready to go once all the metal issues are handled. Or actually AS they are handled. Doing the car one small area at a time. No choice in the matter. Don't have a crew working on it and limited amounts of time. I am also going to look into the Rust Mort option and see how that works with the metal area. One issue I am having is getting to the back of the panel. There really is no back as it is a frame rail. It is kind of a tube. Not sure how I am going to spray them down form the inside either. Maybe a grenade tied to a can of primer. LOL Will be seam sealing things as I go. Figure I will get it all painted in epoxy and seal over it with seam sealer. Need to get some form the auto supply store. Thanks again for all your help. This stuff is fun! |
| surface rust | deepsea29c | Body - Exterior | 4 | 03-10-2007 01:58 PM |
| Rust treatment and repair | Riot Racing | Body - Exterior | 27 | 02-27-2007 12:12 PM |
| Best way to remove surface rust | 49studebaker | Body - Exterior | 5 | 10-31-2006 07:30 PM |
| surface Rust? | kevex | Body - Exterior | 4 | 02-19-2006 02:32 AM |
| Completely covered with surface rust...HELP | richall | Body - Exterior | 18 | 11-11-2002 09:24 PM |
