02-09-2011, 07:49 PM
AR Racing
Originally Posted by 64Duece
I read long time ago a post referring to AR Racing Engines from VA. I just received one and will install this weekend. Couple of points - you cannot build this engine yourself for the price you pay, I compared it to the ZZ4 which I was almost ready to buy. Although everybodies engine on the NET is built from a seasoned (old block) it is the specific builders capabilities and internal parts that make the deal for me. I paid $3050 + $190 for shipping and got the motor delivered to Clearwater, FL in 3 days. It is a 383 with Dart Iron Eagles, Eagle crank, Eagle I-Beam rods, rest of the rotating assembly is Speed-Pro. Valve springs and complete valve train is Comp Cams XE series. Motor built with the best of bearings and ARP fastners throughout. For those interested, AR Racing is a "Machine Shop" all work done in-house, not parted out to vendors, therefore assembly is overseen by a couple of guys from start to finish. The numbers are conversative on the HP/Torque side. I shopped engines since last year when the NOVA was undergoning restoration, and I will agree there are many builders on the NET that make some ridiculos claims to HP - mainly in Ariz. and Cal. The reputable ones will talk to you and tell you what you can expect!!! Face it - a small block is a small block - but the internals and the assembly of matching components is what differiniates one from the next. I went with AR since Mark always accepted my numerous phone calls and described the details of his process of engine building up to the time I ordered the motor. No pressure, no hard sell whatsoever. Be aware of those that build "garage motors" and make claims of big-time engine builders, some are on Ebay Any motorhead knows you ain't gonna get 500HP from a 355 with dished pistons and a mild (488 lift) cam, but I see the same motor with diff pistons and cam claiming very diff HP/Torque ratings, and those guys scared me away. Simply put - I couldn't find a better motor/deal than from AR, and they build 4 a week nationally. A small shop doing good things. Engine are not dynoed, but very few do that for the low prices advertised. Check out Jon Barrett engines in OK. They build a nice product and you will even get a sales rep calling every day to push the order. The $3795 motor ends up costing you bout $5K cause they dont want to dyno the motor and then remove the ingintion/fuel system and whatever else is on the advertised inital price. _ I will follow up with my own personally viewed rear wheel dyno #s in a week or so.
I used AR off Ebay and had a couple of issues. However I am in So CA and Mark made extremly good on the issues. Over a year later and my 383 runs like a monster. I LOVE it. I have to agree with everything I read above. Great build.
