Areas to crack check block deck surface - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2012, 08:16 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I recently purchased a magna flux dye penetration crack detection kit. Now im off to find more uses for it other than just checking heads for cracks. Are there any areas besides around bolt holes and coolant passages on engine blocks that should be checked for cracks? If you want to post a picture with a circled or highlighted area that would be very helpful. Thanks
Old 07-17-2012, 12:14 PM
I assume you mean a V8?
The valley is an area where cracks occur. "Freeze" cracks are found on the outside of the block, usually near expansion plug holes. Main bulkheads where the oil hole goes "through" is another. Around the bottoms of the cylinders into the cam bore is another, usually from highly "abused" blocks.
When we "clean and mag" a block, we check the entire block.
Jim
Old 07-17-2012, 01:54 PM
BOBCRMAN@aol.com's Avatar
Jim
x2 dye penetrant is more useful on aluminum.
Old 07-17-2012, 04:36 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Often by paying close attention to what the engine and components look like at disassembly will hint at possible cracks or blown head gaskets. If coolant is getting in the combustion chamber, it will look very clean compared to the adjacent cylinders from the steam cleaning effect. If the gaskets look good, cracks in castings would be the next suspect.
Cylinder heads can crack from the seat into the chamber, from bolt holes to coolant passages, guides can crack although this isn't too common at least in my experience. The chambers can crack between each other, especially the center cylinders where the crossover causes high or uneven heating.
Shown below are several images of magnetic test showing a cracks. These same cracks will also show up using dye penetrant inspection. Bolt holes to cylinders and/or coolant passages are good places to look on blocks. The starter bolt area of a Chevy block is another place that can be inspected for cracks. The starter nose is yet another.
Crack probably from freezing:
Below is a flat head block showing various cracks. A SBC can crack in similar places, especially from the steam holes of a 400 block:
Here's a diesel block, crack at red arrow, probably another at blue arrow. Webbing of a SBC can be cracked in similar places:
An article from Engine Builder mag: Looking For Leakers. There are others I'm sure.
Old 07-17-2012, 09:16 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
One other obvious area is the bore itself. You may find cracking parallel to the deck:
Also you might see it perpendicular to the deck:
When something gets dropped into the engine and it finds its way into the combustion chamber, there's a fair to good chance that the cylinder will crack. It can also happen from detonation or overheating, and from hydraulic locking the engine. That can bend a rod as well so a cracked cylinder would be something to look for if you see a bent rod, and vise versa.
Again, knowing the engine's history helps a lot and watching things carefully as the engine comes apart will often point you to a problem. Best is when you are able to hear or drive the vehicle to know if there seemed to be a problem in the first place. Things like oil in the coolant or coolant in the oil is a good indication of at least a bad head gasket but can also be a cracked casting.
I believe the main downside to dye inspection is it's more expensive to do, it requires some finesse, and can take longer to do. Depending on the type you are using, blocking out sunlight and/or using a special light source might be needed so that's an added hassle.
sleeve/deck surface - expert oppinions needed d1mbu1b Hotrodding Basics 20 03-30-2011 08:49 PM
355 block... small crack abas_abas Engine 2 03-06-2009 05:51 PM
Freshening up old motor, best way to clean deck surface? Ray J Neal Engine 13 06-03-2008 04:20 PM
Small crack in VW block Demondrive Engine 5 02-24-2004 08:08 PM
