argument finisher - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2005, 05:43 PM
GalaxieRoller's Avatar
One o them people who can post
argument finisher
a buddy of mine and I are arguing like crazy wether or not a cam will make his 90 mustang lx coupe AOD run faster than a gear would. please clairify this for me.
Old 07-18-2005, 07:06 PM
i would think gear would make more of a noticable difference.
build for a complete package. make it all work together.
Old 07-18-2005, 07:13 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
It depends on the gear, but yes, the gear change will put more Tq to the ground.
Old 07-18-2005, 07:29 PM
Derkyb's Avatar
The taller gears are just going to make it accelerate harder not necessarly go faster than installing a bigger cam. All depends on your matching parts ability.
Old 07-18-2005, 07:33 PM
milo's Avatar
point on positive
Sooner or later you simply need to shift gears to go faster period. A cam makes the engine go round and a gear makes the wheels go round both are right
Old 07-18-2005, 08:21 PM
Clueless Teenager
Last journal entry: Misc.
With it being an automatic it would be cheaper to go with a gear swap if you were planning on a fairly larger camshaft because you would have to replace the torque converter, but all in all, if the motor is completely stock except for the camshaft you are deciding on, it would probably suit you better with the gear swap anyways.
Old 07-18-2005, 08:51 PM
edge's Avatar
Time is short, are you ready?
This guy is a Troll. In one thread his buddy has a "t-5", and the next it's a "AOD". Lock and dump this with the rest of his threads.
http://www.hotrodders.com/showpost.p...2&postcount=21
try 90lx's old gt: 2.73 (stock) gears, t-5, king cobra clutch, street radials, long tube headers, h-pipe, flowmasters, msd ignition,way advanced timing, did it w/out a timing light, every knuklehead trick in the book: 16.00@90
Ed
Old 07-18-2005, 10:44 PM
Ed
he first had a t-5 in a 1990 gt hatch, when that trans went he got the aod lx (also a 1990)
