Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - A Arm bushing tool
Old 06-19-2006, 06:40 PM
russlaferrera russlaferrera is offline
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
A frame bushing instalation
Propaneburner, there is a special tool made by OTC and Kent More that looks like a C clamp, that has one end that is U shaped (so you can remove it from the bushing). I use a 2X2 angle iron, the length between the A frame with a deep socket on top of the bushing as the driver with a hyd. press Make sure the A frame is clean, so the bushing will slide in easier. Hope this helps! Russ
