-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   A Arm bushing tool (http://www.hotrodders.com/forum/arm-bushing-tool-92019.html)
propaneburner 06-19-2006 04:37 PM
A Arm bushing tool
What is the proper tool to put new a-arm(control arm) bushings in place.?
This question is for a 79 camaro.
I have a press and stuf like that , but these arms are org. from heavy sheetmetal and i dont like to bent them while pressing.
Or just fill the gap with some wood/iron etc.
Thanks all.
russlaferrera 06-19-2006 06:40 PM
A frame bushing instalation
Propaneburner, there is a special tool made by OTC and Kent More that looks like a C clamp, that has one end that is U shaped (so you can remove it from the bushing). I use a 2X2 angle iron, the length between the A frame with a deep socket on top of the bushing as the driver with a hyd. press Make sure the A frame is clean, so the bushing will slide in easier. Hope this helps! Russ
sha_ba_do_bang 06-20-2006 04:13 PM
you should be able to slide it over the press so your only pushing on on leg and the other side hangs below the press, i wouldn't buy the tool if you have a press
sockets make excellant bushing drivers!
Brendan
Koolaid 07-12-2006 06:28 AM
Uppers or lowers?
Lowers: cut out the originals, get some 2 x 2 x 1/4 angle iron - make some precise fit spacers to go in between the two gaps. Note that due to stuff moving around and being old you might have 4 different lengths cut for the 4 lowers, but odds are you're right and left will be the same. Just make sure you have it snug enough so that it won't fold and then press it in.
Uppers - You can press the first in normally, then drop in the second, make a long spacer so you won't fold the control arm and go to town pressing that one too. I have also had one or two urethane bushings that I could press out of the housing with persuasion so I could press the uppers in normally, then drop in the urethane and use the cross bar as a press of sorts to draw in the urethane.
Just my opinion - I've read about doing uppers while they are still on the car using heat and a hammer, but I'm a little leary of putting heat into the control arms.
Bryan59EC 07-12-2006 06:47 AM
I have - a few times - used an air hammer with a blunt tip - to vibrate them in.
A bit of lubricant and they will usually go right in.
I use the same method to get them out -- sometimes need the chisel though.
(actually did an arm yesterday)
tm454 07-12-2006 08:05 AM
getter dont!!
use a hack saw to cut the old bushing in-two pieces..be careful NOT to cut into the A-Arm. Use the c-clamp tool to push out the old pieces. Use the tool to install the new bushing after cleaning up the hole inside of the A-arm to make it slide in easier.
Tazz
