Armrests In 1960 Rambler Classic super! HELP!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2011, 07:21 PM
Hi there, my name is Nicole and Iím new to the message boards. I recently bought a 1960 Rambler Classic project that we are just starting to work on. Her name is Mable. The interior has been redone before I got her, but they door panels still need to be fixed, Iím having the damdest time getting the armrests off! It looks as if they are riveted on (maybe from the factory) Has anyone else come across this? Any suggestions for me? I donít want to just grind them off if I donít really have to! Please let me know! Hope to hear from someone out there
Nicole & Mable
Old 07-04-2011, 08:01 PM
life is a temporary assignment
A good picture of the arm rest would help us help you... Did you get the door handles off yet ???
Old 07-04-2011, 08:22 PM
Here is a pic of what Im dealing with. No I also haven't gotten the window crank off yet. Is there a trick to that as well?
Old 07-04-2011, 08:39 PM
Uses the tool I posted on your other thread... There is a u shape clip behind the door handle... That tool will pop the clip out of the handle,, Then it will come off...
Old 07-04-2011, 08:44 PM
Thank you very much!
Old 07-04-2011, 08:51 PM
This should be what the clip look's like behind the door handle... That tool will help alot..
Old 07-05-2011, 07:54 AM
DanTwoLakes's Avatar
Wiki Edits: 22
You're right, that is riveted on. You need to remove the window handles, the door handle, and loosen the clips holding the panel to the metal door. There will probably be a bracket or brackets (held in place by those rivets) on the back side of the panel that slip into holes in the door which were used to provide support for the armrest. The door panel will have to be lifted up to release the brackets so you can remove it from the metal door.
This is the best clip removing tool I have ever found.
Old 07-05-2011, 02:12 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
If you are only going to 'one-time' this door handle, don't bother buying the tool. Just use a shop rag, slide the rag in behind the crank handle part and with a sawing motion pull the rag back and forth. The steel clip that retains the handle will grab the rag as you work it and spring out of its groove in the handle allowing you to remove the handle.
To replace the handle, insert the clip in its proper groove in the handle, set the handle over the crank stud and hit it on with the palm of your hand.
Old 07-06-2011, 06:52 AM
Wiki Edits: 22
The shop rag trick works when there is space under the handles for the rag to maneuver. If the handle is tight to the door panel it may not work.
Old 07-08-2011, 12:05 PM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
GcChick, the 60 Rambler doesn't have that clip. Instead it has a rubber base between the handle and door. Push the rubber in and you will see a pin hole. Push the rubber in at the bottom once you find the hole and the pin will fall out (catch it!!). The spring clips weren't used until 63.
Looks like the arm rest is indeed riveted to the door panel. It should come off with the panel. Once you get the clips out of the edge of the panel, slide the panel about 1/2" TO THE BACK (toward the back of the car) then pull the panel off. There is a stud that goes in a keyway behind the panel. Don't grind the rivets off!!
I suggest you check E-bay or Faxon Auto Literature for a 1960 Rambler TSM (Technical Service Manual -- the factory repair manual). That will prove most helpful, well worth the $30-60 it will cost!!
Old 07-08-2011, 12:06 PM
Wiki Edits: 647
I guess we solved that problem!
Old 07-08-2011, 08:58 PM
yes, problem solved! door pannels off! thank you! <3
1960 Rambler American engine swap Ramblin' Man Hotrodders' Lounge 35 05-16-2013 08:27 PM
Rambler Classic Hotrod GunnerTHB Hotrodding Basics 18 12-08-2008 09:09 AM
1960 rambler transmission question robsan Transmission - Rearend 2 06-21-2008 05:11 PM
1960 Rambler Ramblin Root Introduce Yourself 3 10-02-2006 10:47 PM
hello, 62 rambler classic das24rules Introduce Yourself 1 05-19-2006 09:35 AM
