A Arms - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2012, 10:30 PM
A Arms
I took the old A arms off my 69 nova because of rust and they just didnt look right. I am wanting to replace them along with all the front end parts. There are so many different types of A arms out there how do you make a choice of what to use? I mean there are prices from 269. for all 4 to 5-600 dollars for the uppers and the lowers separate. Can anyone help me with this? Thanks Glen
Old 12-11-2012, 10:35 PM
blast them fill the pits with polyester putty prime them paint them
Old 12-12-2012, 05:18 AM
Irelands child's Avatar
It depends on what you are looking for. If you just want reasonably priced control arms for street driving - do as the above poster suggested plus replace any bushings and ball joints - that is unless you find cracks or bends. If you want handling then you have to look for a version that is reinforced/heavier steel plus have poly bushings and HD ball joints. Next, you get into the tubulars ........ shiny? painted? heavy duty? coil over suspension?
Irelands child
Old 12-12-2012, 06:51 PM
vinniekq2's Avatar
tubular a arms are strong and very good.You may want to upgrade the entire front end to make the car handle better? or just get away from using shims to do alignments
Old 12-12-2012, 08:01 PM
starnest's Avatar
elkyholic
Last journal entry: Center Link Installed
Unless you're racing or have a lot of money to spend stay with the stock a-arms. The a-arms designed for your 69 Nova have travelled billions of trouble free miles.
If they are bent, cracked, or the bushings have hogged out the holes they mount in replace them; otherwise clean, prep, and paint. Replace the bushings and ball joints while they are out.
Be sure to check the idler arm, center link, and tie rods before you put them back on.
a arms 33 plymouth 5 window Suspension - Brakes - Steering 2 03-10-2012 04:23 AM
Tubular A ARMS petes67bird Suspension - Brakes - Steering 8 10-20-2011 11:58 PM
Rocker arms byrddogg65 Engine 4 07-09-2011 06:51 PM
Rocker Arms 1970NovaBoy Engine 8 12-11-2006 11:21 AM
fabricating a-arms? Gearhead forever Suspension - Brakes - Steering 4 03-12-2003 05:13 AM
