Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ARP head bolts
Thread: ARP head bolts
Old 10-12-2013, 02:55 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
They were done correctly....RTV silicone sealer, #2 Permatex, or Teflon pipe thread sealer on threads, and motor oil or anti-sieze under washer and bolt head.
Assuming this is the SBC you are working on....
Torque to factory spec (70 ft.lbs.) in the proper sequence, in at least 3 steps - i.e. 25 ft.lbs. then 50 ft.lbs. then final at 70 ft.lbs.
Last edited by ericnova72; 10-12-2013 at 03:23 PM. Reason: wrong torque spec in one section of post
