Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ARP head bolts
Thread: ARP head bolts
Old 10-17-2013, 06:18 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by maddart View Post
I was going to use the ptfe on the threads and vaseline under the head bolt/washer. I have a builders book recommending vaseline. Thoughts?
Vaseline is not a high pressure lubricant- which is what you want under a washer that's seeing a big clamping load as well as a high frictional load. Moly-based lube is best used in these applications.
