ARP main studs question (for my 489 build) - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2011, 04:58 AM
Hello everyone!
I'm building a stroker 489 torque monster for my 4x4 79 Blazer.
So I got new ARP main studs for it. During the machining process, I got the mains align honed. Then the caps were ground down to get the right clearance for the crankshaft. The thing is that they had to replace and retorque the caps about 5-6 times during the process. I still have to do the final assembly after cleaning it, so that's one more torque down for the studs. I've read somewhere that ARP bolts stretch permanently and shouldn't be used more than 5 times. Can I still use these studs? Or am I risking something getting damaged in the long run due to an incorrect torque reading?
Thanks!
Old 04-26-2011, 10:17 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
I've never heard of a stud being unusable after five torque downs, the number of times it's torqued isn't the deciding factor on weather it should or shouldn't be used. Heck you can over stretch it on the first torquing. The correct way is to measure it.
If you measure a fastener and it is 0.0005˝ longer than its original length, it has been compromised and must be replaced.
Rich
PS Call ARP they'll tell you the same thing.
Old 04-27-2011, 12:54 AM
Thanks for the good news Richard. What about ARP rod bolts. Are those more prone to failure?
Old 04-27-2011, 07:47 AM
Irelands child's Avatar
Some of the newer cars have single use bolting, I know Ford with their modular engines specifies some bolts be replaced, which is probably where that kind of information originated. I agree with Richard - and especially since there has not been any heat cycling of these fasteners.
Dave W
Irelands child
Old 04-27-2011, 08:19 AM
Bolts only need to be discarded after use if they are of the torque to yield type. And even then, most headbolts can be reused once or even twice depending on how they are being torqued down. I don't know about studs though which is the specific topic here, so i'm subscribed for more replies but seems Richard already nailed it
Old 04-27-2011, 11:54 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Blazer79
Hello everyone!
Thanks!
Actually, repeated tightening and loosening cycles will burnish the threads and in the end will give a more accurate reading than would fresh, one-time-tightened fasteners.
From a '98 ARP catalog:
The friction factor changes from one application to the next. That is, the friction is at its highest value when the fastener is first tightened. Each additional time the fastener is torqued and loosened, this value gets smaller. Eventually the friction levels out and becomes constant for all following repetitions. Therefore, new fasteners should be tightened and loosened through several cycles before applying final torque. The number of times depends on the lubricant. For all situations where ARP lubricants are used, five cycles are required before final torquing.
This may have been supreceded, but I believe they still call for cycling the fasteners through a couple tight-loose cycles.
Old 04-27-2011, 12:31 PM
Hi
Any fastener in that environment (Rod Bolts, mains, etc.) are subject to failure, all you can do is try & make it as bullet proof as possible.
This is don by using the best parts your able to afford & close attention to detail.
Well ARP has been at this for awhile (1968) & are considered the best of the bunch. Back when I started & I'm sure a lot of the older men remember when it was a crap shoot as to weather the thing was going to stay together, the quality wasn't there in the fasteners, many engines failed due to the fasteners inability to handle the stress. Today it's much different, now when I put an engine together I no longer worry about the fasteners not being up to the task. I use ARP fasteners exclusivity.
Rich
PS Normally when you see an advertizement for connecting rods, you'll read "rods have been upgraded to ARP fasteners/bolts"
X2 with the cycling of the fasteners.
main cap studs garand wizard Engine 4 12-12-2010 12:57 PM
Main studs too short BringBackTheCamaro Engine 3 02-26-2006 04:16 PM
Main Studs Not Long Enough Canadian Charlie Engine 5 02-09-2006 12:25 PM
ARP Main Studs Kit Canadian Charlie Engine 7 02-05-2006 05:45 AM
Need Advice On The Use Of Main And Head Studs GoneNova/406 Engine 16 01-19-2005 06:15 PM
