ARP Nuts - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2008, 09:23 AM
ARP Nuts
ARP connecting rod nuts have one side plain, and the other side has a series of concentric grooves. Which side goes against the rod cap?
I assume the grooved side, as they must be there for a reason. Is this correct and does anybody know the reason?
My best guess is the grooves hold oil for lubrication which means a more accurate torque application, but I really don't know.
Old 12-18-2008, 11:49 AM
racecar100's Avatar
It dosen't matter which way it go. All that marking is the nut grade code.
Rocker Arm Adjusting Nuts Problems - Help Me Diagnose leejoy Engine 8 11-26-2008 06:14 AM
Starter nuts?? APalusky Hotrodding Basics 4 08-25-2008 08:23 PM
Torque spec question ARP bolts surfshark Engine 3 10-14-2006 10:15 PM
Lug nuts for wheel studs lluciano77 Transmission - Rearend 1 10-26-2005 09:34 AM
ARP head bolts. TVR383 Engine 4 04-08-2004 11:45 AM
