assembling a 402bbc for a 82 corvette - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2011, 06:53 PM
Hay! I need to know if my combination of parts will work ok in my 402bbc. I have the block #3999290 which is boored out .060 rods & mains are .020 I have Keith Black 160 060 Hypereutectic pistons. Molly SLPE 243K60 ring set. The heads are 3993820,valves & springs seam ok. Had the heads cleaned @ a shop. ERSON cam grind#E120221/w H.lifters and new pushrods. RPM performer 7161 intake. I do not have a carb as yet.
Can anyone Who knows about this stuff give me some input PLEASE?
I can tear a car down to the frame, and put it back, but i am not knowledgeable about engine building combos.
Old 10-24-2011, 07:01 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
If i was you i would also post this over in the engine section we do have some awesome engine guy's around the site.
Cole
Old 10-25-2011, 07:20 PM
eloc431962's Avatar
Wiki Edits: 37
I thought someone would have posted by now.
Cole
Old 10-31-2011, 12:46 AM
Captain Obvious
ok so a little more information. What are the specs of the cam. lenght of rods. and what springs and things do you have in the heads. thx
Old 10-31-2011, 05:49 AM
6426yy's Avatar
You going to run a stock hood? I doubt the RPM and big block will fit under one
Old 11-01-2011, 04:11 PM
55 Alive 402 dilemma
Hi fellow rodders; Ok so here i am again. The cam that i have is an erson #E120221 RPM Rating, DUR, DUR@.050", Gross Lift, Lobe cent, Adv.,V.L.
2,250 310in 2260in .530in 114 4 .000
5,400 310ex 2260ex .530ex .000
the original bore was 4.125 now .060 over. the stroke 3.760 i do not know right off hand the length of the rods i just know they are the original ones for the motor. the springs are the original ones also, they even have the valve rotator eliminators under the springs.
assembling new heads fast on the water Engine 2 11-03-2009 07:37 PM
Assembling process.... sexypizzaman Engine 8 01-06-2008 05:21 PM
assembling float pin / rod Rocket455 Engine 20 04-19-2006 01:24 PM
Assembling a 351W MeligN Engine 3 11-06-2005 03:16 PM
NOT Assembling a 327/completely tm454 Engine 5 11-26-2002 09:14 PM
