Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Assembly Lube on Cylinder walls
Old 09-01-2008, 05:09 PM
machine shop tom machine shop tom is offline
King of my Man-cave.
Originally Posted by va4cqd
moly rings do take longer to seat then cast rings
Moly rings do NOT take longer to seat in a properly prepared cylinder.
Was the block torque-plate bored and honed? What grit stones were used? Were the bores plateau-honed? Were the rings installed correctly (second compression rings installed upside-down will cause what you describe)?
What is the brand and part # of the rings used? Perhaps they are low-tension rings.
tom
