Assistance with my 383 >
Hey fellas, I'm pretty green to Engine Building. I have a Freshly rebuilt 383 stroker.
2 bolt main Bored .30 over Comp cams magnum 270h hydraulic flat tappet cam & lifter kit Comp cams push rods Comp cams magnum double roller timing chain High flow oil pump Freshly rebuilt port & polished 202 heads Now, I am probably just going to drive my car to work daily, all highway for about 15 mins. one way. I have two Intakes , an Edel Preformer & an Edel Torker 2 & a Holley 700 DP. I know I need a bigger cam & plan on going up to a 285. What intake should I go with ? |
with the current cam it wouldn't make sense to run anything that will run over 6000 RPM, maybe less. Use the performer for now. If you do upgrade the cam later consider something with higher RPM potential (although I'd still strongly recommend a dual plane).
K |
Torker 2 is an awful intake, stick with the performer, unless you have a lot of compression and some decent gears I wouldn't change the cam either.
Thanx guys ! I appreciate it tremendously !
assistance with my 383
with my 454 z28 i ran the same 1/4 mi. times w/ enither intake. t6hrottle response was similar. although i had the old schoole torker w/ thetwisted carb location.
What you should consider is an RPM or knock-off. Air Gap if you must, but I like just the RPM- although this is solely based on here-say. You can fart around w/spacers on either one and gain (or lose) power. I'd suggest making your own, buy them at a swap meet or be prepared to shell out some coin. Open spacers can be found cheap, but the double throw-down swirly-twirly ones are $$$. |
here is a nice intake comparison.
http://books.google.com/books?id=Y98...age&q=&f=false it is on a bbc. the performer and torker make the same peak hp and torque. But the performer made max torque 600 rpms sooner. That is what I felt in my sbc power z car when I tried the torker. |
| 383 stroker v.s. 383 chrysler ...the end | mcharger440 | Engine | 58 | 12-07-2012 08:16 AM |
| 350 vs 383 build for performance | Biscuit6447 | Hotrodding Basics | 20 | 03-05-2010 08:42 AM |
| Check out this find! | bonuts | Hotrodders' Lounge | 12 | 03-31-2003 03:10 PM |
| What do you do????? | SCREWEDnTATOOED | Hotrodders' Lounge | 3 | 12-09-2002 08:40 PM |
| ghost story | awsum34 | Hotrodders' Lounge | 8 | 11-02-2002 04:03 PM |
