Astro column /shaft on Mustang II rack? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2007, 12:26 AM
staleg's Avatar
Last journal entry: Home made gear stick
I'm going to use a steering column from a Chevy Astro. I have bought, but not yet received, a complete column included joints, pipes and shaft all the way down to the stering box.
It will be used on a 34 Ford with a manual Mustang II steering rack. The steering pin dimension on the rack is 9/16-26 splines (isn't it?)
Can any of you help me with what I need in addition to my Astro parts?
Will for example the Astro/S10 steering box joint fit on my Mustang II manual rack?
Old 03-02-2007, 11:52 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Unlikely but Borgeson can supply any adaptor you need.
mustang II/ thunderbird rack question sfd771 Suspension - Brakes - Steering 7 05-12-2012 08:57 AM
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
Mustang II rear steer rack??? staleg Suspension - Brakes - Steering 2 04-05-2006 03:23 PM
Mustang II Power Steering Rack Dave42 Suspension - Brakes - Steering 7 02-13-2006 05:26 PM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 12:43 PM
