Astro Evo4014 - Help Needed Please - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2006, 10:08 PM
I have this gun and am looking for a compressor for it. Do you look for a compressor's CFM @ 40 or 90 for this LVLP gun?
Here are my options:
Craftsman
6.4 CFM @ 90
No CFM @ 40 listed
26 Gallon
2 HP
Oil free
Accessory kit
$277
vs
HF
3.5 SCFM @ 90 PSI
8.8 SCFM @ 40 PSI
21 Gallon
3 HP
Oil lubricated
$150
vs
HF
5.6 SCFM@90
7.2 SCFM@40
8 Gallon
2.5 HP rated motor
Oil lubricated
$100
The last one has higher CFM @ 90, whereas the middle one has higher CFM @ 40. Which is more important for LVLP Astro Evo4014? Thanks.
Old 10-13-2006, 05:56 AM
astroracer's Avatar
None of them... Too small, way to small! Your Evo is going to require almost 10cfm at 25psi operating pressure. None of those little compressors will be able to keep up. The problem with HVLP guns is they are cfm hungry. You really need a larger compressor to get full benefit of your HVLP guns.
I was running mine on a 5 hp/60 gal single stage and the compressor would run out of breath about halfway through a job. I stepped up to a 7.5 hp/80 gal 2 stage and the gun works like it is supposed to now...
Mark
Old 10-13-2006, 07:12 PM
Mark
I understood this gun to be LVLP?
Old 10-16-2006, 04:14 PM
astroracer's Avatar
It is an LVLP, my bad, but that doesn't change the specs...
This is taken right off the Astro Spec page...
Astro Pneumatic LVLP Spray Gun - EVO4014 - LVLP Gravity Feed Spray Gun
• LVLP Spray Gun with Patented cap nozzle design and use of lower volume of air finely atomizes paint creating a smooth finish with minimum overspray
• Stainless steel needle and fluid tip makes it suitable for water base products
• Decreased overspray creates cost savings over conventional spray guns
Specifications:
Nozzle Sizes: 1.4mm
Operation Pressure: 25psi
Gun Weight: 1.021lbs
Avg. Air Consumpt.: 9.6CFM (7.8@40)
Air Inlet Thread NPT: 1/4"
Recommended Compressor: 3hp
Max. Pattern at 8" Distance: 8.5" - 9"
Air Hose I.D. Size: 1/4"
Comes with .6 Liter Plastic Cup
10PSI operating pressure
Average air consumption @ 25psi is almost 10cfm. You will need a bigger compressor then the little ones you have listed... Like I said in my first post, I had to step up to a 2 stage to get enough wind to run my HVLP guns and your LVLP is the same cfm hog the HVLP's are...
Mark
V8 Astro Van C10 Hotrodders' Lounge 24 02-28-2012 03:57 PM
Has anyone used the New Astro QUL103R HVLP camaro freak Body - Exterior 0 04-18-2006 08:10 PM
Astro hvlpdx3 or evo4014? DougMN Body - Exterior 2 03-15-2006 09:04 PM
spring perch no welding needed ??? Can drive 55 Transmission - Rearend 1 10-07-2005 07:36 PM
Spot weld driller Shoot out! MARTINSR Body - Exterior 5 05-30-2005 05:46 PM
