astro gun pachage hvlp & lvlp Vrs Finex 3000 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2013, 12:44 AM
please help me out with your input on the 2 gun kit bc/cc astro
Astro Pneumatic - AST-QUL HVLPDX3 - HVLP Gravity Spray Gun & Cup
or a finex 3000
also are the astro guns a much slower spraying gun ?
Old 03-14-2013, 01:03 AM
anyone have input at all ?
Old 03-14-2013, 06:26 PM
mitmaks's Avatar
Last journal entry: Grille
I have used Finex and they are great guns for the money. Haven't used Astro.
Old 03-15-2013, 07:55 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
I am an Astro user, and for me it works well (although it won't be mistaken for an Iwata LP anytime soon)-I use the EVO 4014 (1.4 tip), and it works well for what I am doing (I'm just a hobbiest). Everything I've done with it has been solid Colors, so I can't say how well it will work with Metallics-YMMV-
If you are shooting a Metallic I would suggest that you step up to an Iwata or a Sata-the loss of Materials might easily pay for it-
Old 03-15-2013, 09:12 AM
put up or shut up
I have a Finex 3000 and it's a great sturdy little gun for priming. I hear there's an astro gun out there that's also good for priming but has little overspray. Sounds awesome but can't vouch for it personally. I have heard people complain about parts for the finex but it has held up pretty good for me and was once used everyday at a shop. I dog my primer guns too. It gets percolated 90% of the time and then gets a complete cleaning once in a while. No complaints here.
Old 03-15-2013, 08:00 PM
I have an evo 4018, it sprays ok when you start spraying primer but the small holes in the air cap get plugged up from the overspray. The fluid nozzle needs teflon tape on the threads or it will suck air causing surging. I would not buy another one.
Old 03-16-2013, 02:33 PM
i have a finex 300, i use for sealer but it isnt that great for base or clear, ive found that most cheap guns require frequent tip cleaning. on a complete you should clean the air cap every refill. my graco delta xt and sata jet 90 will spray for 2 hours without cleaning .a used devilbiss gti or an old binks bbr would be alot better choice, just my opinion
Old 03-19-2013, 08:23 PM
78rubbernose's Avatar
It' not the arrow.I'ts the indian
I'v spraded with a lot of guns from $1200.00 sata jet's to a $9.00 harbor friaght. I'v been spraying for 30 years so I can use any gun.But to answer your quest the asto can give you a nice finnish.Just make shure you clean every time.take your time check out sum vid's on youtube. Good luck!
Old 03-27-2013, 07:23 PM
i have used an astro for a primer gun since 1994 it works good for a cheapo gun
Old 03-27-2013, 07:57 PM
Moedog07's Avatar
I just bought the AP Europro 1.3 and an Evo4014. Both look like fine guns. The workmanship looks good in both. I haven't used either yet.
finex 3000 spray gun pattern perogers56 Body - Exterior 0 02-01-2012 03:54 PM
Satajet NR2000 vs 3000 b / 3000 hvlp / 3000 rp Top Secret Body - Exterior 1 05-22-2009 09:34 AM
Lvlp or Hvlp Gun zonk Body - Exterior 5 12-24-2007 08:36 AM
Sharpe Finex And Astro Guns HVLP LETHAL-6 Body - Exterior 4 02-06-2006 08:15 PM
