Astro Van Front End - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-10-2010, 07:36 AM
3rdmember
Originally Posted by tbirdscott
I'm pretty sure that till '88-'89-'90 the safari/astro vans had a full frame under them, they were based on the s10 chassis. And i've seen the engines taken right out the front, although I have heard of dropping the subframe before to do it.
you'd be wrong
astro/safari's were NEVER a full frame vehicle
oops, this thread's older than Crosley
  #17 (permalink)
Old 12-10-2010, 09:49 PM
awd 2wd swap
I'm just wondering if I can put 92 2 wd front end parts into a 97 awd to convert it into 2wd. Any ideas?
  #18 (permalink)
Old 12-11-2010, 04:45 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
No, a-frames are different. What can be done is gut all of the AWD parts except for the outer stub axle, separate it from the CV joint and use it with the AWD hubs. The stub is needed to maintain the correct pre-load on the front wheel bearings. You will still be using the torsion bars, there are coil overs made for the Syclone/Typhoon to eliminate the torsion bars, they run somewhere around $700.
front end question jbowman Suspension - Brakes - Steering 8 11-29-2007 09:48 AM
Got 39 Poncho, have front end questions rwruther Suspension - Brakes - Steering 0 05-23-2004 03:32 PM
1965 Impala Front End Suspension Problem EazyDuzIt102 Suspension - Brakes - Steering 2 03-29-2004 06:52 PM
Mustang II front end Question horvath Suspension - Brakes - Steering 35 03-02-2003 05:08 PM
is there any front end alignment people out there? IHAVECHEVYPARTS Suspension - Brakes - Steering 5 11-26-2002 08:10 PM
