ATF at oil change - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2003, 10:58 PM
mitmaks's Avatar
Last journal entry: Grille
ATF at oil change
ive read somewhere on this board that you can add atf at oil change, my question is how much and how long do you run engine with it before draining it all out? if my car takes 5qts do i add one qt and then flush it, and drain? thanks guys
Old 10-24-2003, 11:54 PM
4 Jaw Chuck's Avatar
I've always added 1 quart and then driven the car for an hour, read it somewhere a long time ago. The oil has to be hot at drain time. It's worked on a few sticking lifters for me!
— Han Solo
Old 10-25-2003, 12:30 AM
willys36@aol.com's Avatar
Wiki Edits: 21
My father-in-law did that until his engine one time auto-dieseled after he turned off the ignition. He had the presence of mind to throw something over the carb and kill the engine or it would have blown up. Admittedly, his engine was in terrible condition to start with to have that much blow-by of oil into the combustion chamber but I prefer to just change my oil religiously every 3000mi so I never have to worry about cleaning out gunk.
Old 10-25-2003, 07:54 AM
adtkart@aol.com
ATF, simply put, is a highly detergent oil. It does not provide the lubrication that is normally needed for an engine under stress. Running it for an hour or so will help clean out some of the grime from inside the engine. If the engine is extremely built up, or new, I personally would do nothing. Heavy build up can get broken loose and plug the pick-up screen to the oil pump. It should do no harm to the engine under normal circumstances.
Old 10-25-2003, 09:02 AM
302 Z28's Avatar
I would not run it for an extended time, only an hour or two at most. The best insurance is frequent oil changes. if your intention is to try and remove a bunch of buildup from a high mileage engine, you can do more harm than good. All that sludge you have broken loose will quickly foul the oil filter and it will be in by-pass opearation which will then circulate all that garbage through the engine possibly stopping up the oil pump pickup or camshaft galleries.
Vince
Old 10-25-2003, 10:35 AM
former member of HR.com
I ran a half-quart the night before I changed the oil and it did OK in thinning it out and cleaning it up. Funny thing also is that it did clear out some lifter noise too, so I was happy. Total time running was 2-4 hours in just normal driving conditions. Yes it was also warm when I drained it.
Old 10-25-2003, 11:46 AM
ATF fluid is just mineral oil folks with a special additive package, won't hurt a thing. The synthetic type is just synthetic oil with an additive package, no mystery, ask any oil producer what is in their ATF products and you will see they are composed of at least 95% base oil stock. The detergent package is must higher than conventional motor oils so they clean more effectively, thats all.
BTW, ATF is 15 wt in case you want to use it in your motorcycle forks etc. Been doing it for years.
— Han Solo
Old 10-25-2003, 12:06 PM
302 Z28's Avatar
I do not disaggree with what you are saying about ATF, but I will relate a story that happened to me. I work for DuPont and one of the products we make is an elthylene elastomeric rubber, One of our customers is Castrol. They use our synthetic rubber as a viscosity modifier in their motor oils. One time we got the rubber a little off spec and no one caught it in the lab. It caused some problems at Castrol when they ran a quality check on their motor oil. A Castrol engineer came down to help iron out the problem. We had a long conversation on motor oils and ATF. He told me that ATF is the most engineered lubricatant known to man. He never mentioned that it is mineral oil.
Just for thought
Vince
Old 10-25-2003, 12:27 PM
mitmaks's Avatar
Thumbs up
i sure will use it on my next oil change, this topic should be put in knowledge base. What brand of ATF would be best, or just any would be good enough? What about putting it when in when i run synthetic oil? would that do any harm? or would it work with synthetic oils too? thanks guys
Old 10-25-2003, 01:48 PM
OddRodder's Avatar
CORNFED and INBRED !?!
This is an age old practice that began back when PennZoil and others had a parafin (wax) base. these oils left a waxy buildup on everything in the engine, and extended times between oil changes made things worse! Todays oils are much better than those of 20 years ago, and the ATF probably isn't needed. But, if you have some lifter noise or have been a little neglegent on oil changes, then it's worth a try. I have never worried about brand or type in this instance, but I have used dexron instead of type F. just my preference though!
Old 10-25-2003, 02:11 PM
Just for thought
Vince
Funny I had just the opposite experience, I had done some contract work for a major oil distributor here in Wpg. and I needed some dye to find an oil leak in an accumulator tank system (16 tanks) for another job, they were all interconnected and the leak was not visible so I decided to ask these guys if they had some sort of tracer or marker I could use (I was looking for an ultraviolet light visible marker actually). I was taken into a large warehouse where a guy opened a paint cabinet which held a few different 1 liter cans. He gave me a can that said "Red dye#1" or something like that and told me to give it a try. The liquid inside looked like mercury but when added to oil looked red or orange depending how much you added, it was very potent stuff and you didn't need much to tint an oil. I added 1 ounce to a 100 gallon accumulator tank and it was blood red after.
During our conversation he related that this was the same stuff they use to tint ATF fluid, he said you add so much for Type F and so much for Dextron. There was another bottle of additive agent they added for auto transmission use but straight tinted mineral oil is what you get when you buy plain hydraulic oil. Since this was the guy who did this at the plant I believe what he said, all he did all day was blend the oil and bottle it for store sales.
Sure enough when I experimented with different amounts of the dye I could get any color from light orange to blood red depending on how much I used. He also said that straight mineral oil does not foam, it's only when you add detergent will it foam hence the need for an additive package added to the basestock.
When you think about it why do you need anything other than straight mineral oil? Radial aircraft engines run on straight mineral oil and use a sludge tank to trap stuff that gets into it, detergent just keep the dirt in suspension so it can be filtered out and will stick to the metal sufaces inside the engine instead of falling to the bottom. Just like your dish detergent.
The detergent package is what makes the mess. Try it yourself, take some ATF fluid and throw in some dirt from your garden and give it a shake, then take some straight mineral oil and do the same. Let it sit for a day and see what happens. You will see the dirt stick to the sides of the container and most will stay in suspension turning the oil murky, the straight mineral oil will settle out the muck on the bottom and stay clear. I'm sure there is some kind of seal conditioner added to the additive package as well but in the end what your buying is straight mineral oil with a little dish detergent and some paint thinner added for seal swelling and a little kerosene/diesel fuel to keep the foam down. Companies like Dupont spend millions of dollars designing molecules that have certain properties to meet certain specs but in the end it's added in minute quantities to straight mineral oil and sold at an extraordinary profit. I seriously doubt it makes much difference in the end.
Hope I didn't burst any bubbles out there. My best advice is change the oil regularly to get the gunk out and forget the fancy oils although I do think synthetic based oil is superior in every respect, now if only I could find some straight castor bean based synthetic oil by the barrel for a reasonable price. I would use it for everything from brake fluid to motor oil.
They can keep their expensive oil additives, I would rather change it more often.
— Han Solo
