-   -   ATF vs Power Steering Fluid? (http://www.hotrodders.com/forum/atf-vs-power-steering-fluid-30274.html)
Jag Daddy 12-15-2003 11:44 AM
I bought a bottle of ATF the other night and it says it can be used in the power steering pump. Is that true? Can I use it in my GM pump? What about mixing with whats left in the system?
Regards
Mark:eek:
Jmark 12-15-2003 12:22 PM
Hi Mark, Mark here.
I've used Dexron tranny fluid in all my GM cars for over 25 years and never had a problem.
Having said that, the imports are different. I believe that the Hondas require their own PS fluid. If you use ATF in them, the rack, hoses and pump take a huge dump.
Mark
