ATI Procharger - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2003, 02:59 PM
Chevymetal's Avatar
High Octane
ATI Procharger
I wondering what you guys think about ATI Prochargers. The reason is there is a guy selling a fairly new P600B for a carburated sbc. He put it on a old truck he had and decided to sell the truck, but took the supercharger off of the engine before he sold it. He is asking $1200.00 for the complete setup with no intercooler.
Does anyone have experience with this particular setup? I have been wanting to do another engine build up but I just can't decide between nitrous, supercharger, or stroking the mess out of a sbc.
Either way I go I will have to rebuild my current set up due to bottom end weakness.
Here is my current set up:
400 sbc .060 over 2-bolt main
11:1 Forged flat tops
Dart 1 Pro aluminum heads 2.08/1.60 230cc
Hyd. Flat tappet .519/.523
Stock cast crank (weak link)
Comp Cams 1.6 roller rockers
Weind Team G intake w/2" raised plenum
Holley 4150 750dp modified to flow 830cfm
Super Comp Headers 1-3/4 primaries
This is in a Full bodied '66 Chevelle with a turbo 350 trans, and 4.56 gears.
7.57@98 in the 1/8th
I am wanting to run the 7.0 heads up class or at least put this thing in the high 6's
Any suggestions?
Old 10-09-2003, 03:02 PM
unstable's Avatar
Murderator
Last journal entry: Brackets, Stories and the future
well I know for a fact you'll need to run lower compression pistons. Something like 8:1
Old 10-09-2003, 03:12 PM
IMO they are one of the best superchargers of that type.
They put out insane amouts of boost while keeping the air intake charge cool (thanks to the intercooler)
Old 10-09-2003, 04:03 PM
Chevymetal's Avatar
High Octane
Unstable,
Yes, I certainly agree. This would be a definite part of the rebuild (lower compression).
thanks
Old 10-09-2003, 04:15 PM
I wouldn't put it on that block. 400's were thin, and if you haven't had it sonic checked I would say the cylinder walls are at .130 to .140" thick. With a blower you may split the cylinder walls.
As far as ATI it is good stuff. Wild jetting is what I have run into on some marine stuff. Other then that neat system.
CStraub
Old 10-09-2003, 04:47 PM
Chevymetal's Avatar
High Octane
CStraub
CStraub,
Thanks for the imput. I agree. I have considered going for the 'gusto' and purchasing a Dart Little M block to support the kind of abuse I want to put on an engine if I went with the supercharger, but that's where the big money comes in (buying the block) and I start thinking...what else could I build with that money?
