Attaching Laminated Deck Skin? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2010, 04:02 PM
Well, I did it. Ill post some pictures soon. I'm hoping that I attached the hog ring correctly by attaching them under the seat springs on the side. This left me with a hog ring free top to glue my foam onto. Did I do it correctly?
Old 06-07-2010, 11:43 PM
DanTwoLakes's Avatar
Wiki Edits: 22
That sounds like you did.
Old 06-08-2010, 10:45 AM
How tight should it be? Its not flopping all around but it isnt skin tight.
Old 06-08-2010, 10:57 AM
Wiki Edits: 22
It doesn't need to be super tight because the foam and seat cover will hold it down to the seat spring assembly. You just don't want it shifting around.
I just re-read your first post. The hog rings should be attached to the border wire around the perimeter of the seat frame, not to the springs under the border wire. Look at the last picture in this post: CLICK HERE
If you attach the deck pad to the springs, you may create a situation where the springs don't function correctly. The deck pad is there to keep your seat foam from being cut by the springs and pushed through as the seat is used.
Old 06-08-2010, 04:04 PM
http://www.hotrodders.com/forum/attachment.php?attachmentid=31896
do u mean this picture?
Old 06-08-2010, 10:08 PM
Wiki Edits: 22
That's the one.
Old 06-14-2010, 02:57 PM
Elleka's Avatar
Last journal entry: Old interior
I have looked high and low for the laminated deck skin you describe, but can not locate it anywhere. Dan, where do you get it, or do you have any??? Thanks.
Old 06-14-2010, 04:11 PM
Wiki Edits: 22
I have one supplier that I get it from, but they only sell to upholstery shops. Yes, I have some I can sell you. PM me and I'll get your shipping address.
Quarter skin questions... 7StangG2 Body - Exterior 29 08-07-2009 11:52 AM
Stock 350 Rebuild cprice72 Engine 17 04-12-2009 09:51 AM
2005 Acura RSX door skin replacement question cyclopsblown34 Body - Exterior 5 03-26-2009 04:23 AM
Door skin installment sevt_chevelle Body - Exterior 17 01-20-2007 06:35 PM
Is all laminated glass equal? cboy Body - Exterior 11 05-20-2005 06:25 PM
