Attaching wood to fiberglass - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2010, 11:25 PM
I am adding some wood strips to my all glass 32 ford coupe. These strips will be used to attach interior panels. What is the best way to attach the wood. Looks like most of the wood in the car now has been attached with some sort of puddy or bondo. Thanks for any help.
Old 11-14-2010, 11:39 PM
Construction adhesive would work I think. Rough up the glass with coarse sand paper.
Old 11-15-2010, 08:16 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Let's move this to Body Exterior. There are far better things to use than construction adhesive.
Dan
Old 11-15-2010, 08:53 AM
Wiki Edits: 27
glassing in the wood.
I printed out an article on glassing in T bucket bodies, I've got 2 in the shop.and a glass 32 that need wooded. It was according to my notes posted on killbillet by donsrod. I did a search and didn't find it today. I have seen some glass cars that will show thru where the wood is after the glass cures, basics is to clean the surface with laquer thinner, grind the surface then wash with dawn dish detergent, use polyester I've read that some guys space the wood away from the body with molding clay so the glass bridges over the wood. real steel is easier.
Old 11-15-2010, 09:07 AM
delawarebill's Avatar
wood to fiberglass
when i built both of my buckets i used bondo to stick the wooding to the glass to mount interior panels... never had a problem of comming off... prep is a biggie..
Old 11-15-2010, 02:31 PM
ogre's Avatar
the 'Duracell Project'
use .75 oz fiberglass mat and resin to attache wood to fiberglass
sand/grind the back of the glass flat, taper the edges of the wood or use filler
apply a layer of filler under the wood and then 3 or 4 layers of .75 oz mat over it
it will never come off
for small pieces use supper glue to fasten it and then glass over it
fiberglassforums.com
Old 11-15-2010, 03:05 PM
ogre's Avatar
wood ready to glass
glassed wood. these ribs are structural to keep my toneou cover from flexing
this works to attache metal, too. these are my hinge studs on a metal plate.
i bolted the hinge plate to the hinge, smucked a little duraglass on them and set the toneou cover on them let the filler set up.
pulled the cover off and then 4 layers of fg mat to lock them on.
finished product on pic above ^^^
Old 11-15-2010, 03:14 PM
Rag top bird's Avatar
Hot rods are still the king
Originally Posted by ogre
wood ready to glass
This will work I done a boat 5 years ago the same way as you have and you know boats take a betting
Old 11-15-2010, 05:26 PM
I've used construction adhesive for a lot of things, and just because it's doesn't say automotive on the package, doesn't mean is isn't any good. Loctite makes a great polyurethane construction adhesive that fills gaps with ease, and adhesion is only limited by the materials it is bonding......John
Old 11-15-2010, 08:30 PM
I dont dout that it would hold up my question would be how well will fillers and primer bond to the adhesive
Old 11-15-2010, 10:30 PM
wood to fiberglass
Good info! Thanks everyone!!
Old 11-16-2010, 08:58 AM
Wiki Edits: 22
I didn't say construction adhesive wouldn't work, I said there were better things to use. That's why I moved this thread to Body Exterior, the guys here would know what's the best thing to use and the best way to do it.
Old 11-16-2010, 09:20 AM
RAYFIN's Avatar
Last journal entry: before picture
Windo Weld
Old 11-17-2010, 08:40 AM
302 Z28's Avatar
Ogre has the ticket, good work
Vince
Thining fiberglass resin to spray. Is it possible? smithkustoms Body - Exterior 17 01-08-2010 09:15 AM
Reinforcing fiberglass firewall for attaching A/C msford34 Body - Exterior 2 05-02-2008 03:48 PM
Sanding the *%^$&# primer all off the fiberglass parts Ripped Body - Exterior 7 09-01-2007 08:56 PM
Fiberglass or wood handles? Kruzin Karl Body - Exterior 8 06-09-2006 06:06 PM
33 Chevy 5 Window Top Chop FREEFALL Body - Exterior 25 02-25-2005 08:59 PM
