Attachments - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Off-Topic
Old 10-02-2006, 04:27 PM
How Does One Go About Making A Picture File Smaller So That I May Attach Some Picture Of My Projects.
Old 10-02-2006, 04:54 PM
mosstrooper's Avatar
If you have a Digital Camera to take the photos then Software to resize and improve your photos should have been supplied with the camera, usually it would be Photoshop Elements.
Failing that, you can change the settings in your camera to give a photo of suitable size for the web, around 600x400 pixels would be fine.
Old 10-02-2006, 05:38 PM
WakBordr7387's Avatar
Gone fishin'
Last wiki edit: Removing stuck fasteners
Last journal entry: blah.......again
Wiki Edits: 2
Make sure you are not saving your files as .BMP files.
BMPs take up alot more space than other file types that are pictures of the same size.
Try and save them as JPEGs or GIFs if possible to make the file size smaller, but not the picture size.
Brad
Old 10-02-2006, 05:55 PM
SuthnCustoms's Avatar
Crazy Ole Ironhead
go to IrfanView.com and download this software for free..ive been using it for years & its great for downsizing & changing formats etc & very easy & quick to use
Old 10-02-2006, 06:22 PM
thanks for the fast responds everyone. I will be attempting to do them all to see what works best. starting with the Irfanview website
Old 10-02-2006, 08:04 PM
Gone fishin'
Wiki Edits: 2
If that program doesn't work, its actually pretty simple to change the format.
Usually you can open the pic up in MS paint, and go to save as, then select file type(its under the filename) then just pick the type you want.
Or you can go the more complicated route, When your on the folder on your computer, there should be a menu called "Tools" and under it you will find Folder Options. Click on it and it will bring up a panel. Then click the tab at the top that says "View", Then scroll down and you will find a check mark box that says "Hide extensions for known file types" Uncheck it and press ok.
Then all the files on your computer will show the file type in the name for example, the name was "Photograph" will now be "Photograph.bmp". Then you can change the file name just as easy as renameing it by clicking ONCE on the name, and change the .bmp to .jpeg. Just be carefull when you rename other things that you don't delete the file type on other files, otherwise your computer won't recognize the file type and will be pretty much useless.
Brad
Opening attachments in new window Kevin45 Hotrodders Site Suggestions and Help 2 02-21-2005 05:21 PM
Posting Attachments?? Dave E Shank Hotrodders' Lounge 1 11-09-2004 08:44 AM
Attachments in Project Journal meanroy Hotrodders Site Suggestions and Help 1 06-09-2004 06:39 PM
Need help with motor mount attachments phillyfab Engine 2 02-10-2003 08:55 PM
